Help With Wiring Of The SDA CRS That Has The Two MW6510 And One SL2000 Tweeter
13»
Answers
    pitdogg2 Posts: 27,152
    Switch to air tight speakon connection, we've all upgraded to those.
  • Benjisan
    Benjisan Posts: 64
    Yes, I saw that was also an upgrade option to explore.
    Might go that route if I can't find an OEM cable.
    F1nut Posts: 51,872
    ordered the replacement film capacitors and resistors from Digi-key.
    Ummmm...no!
    F1nut Posts: 51,872
  • Benjisan
    Benjisan Posts: 64
    Ummmm...no!
    Why?
    The ones I ordered are audio quality and are just about the same size the OEM's as there's not a lot room for larger caps like Solens or Sonicaps for the crossover board.
    Help me out here if I'm wrong as I can still cancel my order.
    F1nut Posts: 51,872
    edited July 2024
    Benjisan wrote: »
    Ummmm...no!
    Why?
    What brand and models did you order? Digi-key isn't known for quality audio grade components.
  • Benjisan
    Benjisan Posts: 64
    Benjisan wrote: »
    Ummmm...no!
    Why?
    I cancelled the order.
    I found a few threads here that people had used Parts Express and Parts Connexion.
    Will spend some time tomorrow going through them and put an order together.
    F1nut Posts: 51,872
    Try Clarity CSA or Jantzen Superior Z for caps. Vishay-Mills for resistors.
    Madisound IIRC has a good selection of clarity caps.
  • Benjisan
    Benjisan Posts: 64
    Thanks guys.
    Madissound is where I'm putting a order in with. They are USA based and have a great deal of everything I will need from multiple manufactures to do the upgrade.
    Toolfan66 Posts: 18,119
    Driver swap is complete, 6511's should see you by Saturday..
  • Benjisan
    Benjisan Posts: 64
    Toolfan66 wrote: »
    I can not thank you enough Larry in making this a very pleasant interaction.
    And that goes for you too Boston1450.
    All you guys here on the Polk forum ROCK!!
  • Benjisan
    Benjisan Posts: 64
    Toolfan66 wrote: »
    Hi Larry,
    The drivers arrived safe and sound.
    Thanks again.
