New (to me) speaker day!
halo71
I found these a few hours away from me. I went and got the 4th July week. Very nice condition as well. Will need to find 2 MW6503's though. In the pic there are 6 Midwest drivers in the left speaker. The owner gave me 4 working 6503's that I have not installed yet. He said the tweeters are RD0198's. I have not pulled a driver to check. Can anyone confirm they are 198's?
So far I am very very pleased with the $1000 I gave for them.
--Gary--
Nice find. You'd have to pull the tweeters and check the terminals.Don't take experimental gene therapies from known eugenicists.
Only way to tell is by looking at the connection tabs. 198's are two different sizes.
They could be 194’s. Based on the crossover plates, they are not TL’s so the tweeters should be the RD0194.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Those are the first gen sda srs- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Great album!Political Correctness'.........defined
President of Club Polk -
Damn nice score….
Enjoy em for a bit then dive in head first with upgrades. -
Still a great deal even for the original SRS version. For $1K you got six more tweeters than on a pair of run of the mill bookshelf speakers!
Is the interconnect socket blade/blade or pin/blade?SDA SRS 2.3TL's
SDA 2B TL's -
The crossover plate is the give away, the 5 bolts between the handles- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That's unreliable, some SRS 1.2's were sold with the 13 bolt crossover plate. Easiest way to figure it out is if it has a blade/blade IC socket. If so, then they are 1st gen SRS since Polk never made a blade/blade SRS 1.2.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Is the interconnect socket blade/blade or pin/blade?
I asked him that question in a PM response. I have not heard back yet.Political Correctness'.........defined
They look nice, congrats!
They seem like an upgrade from the two speakers in the front there...
Wether or not they are the original SRS’s or 1.2’s those tweeters should be 194’s..
I have 6503’s -
But if by some of chance they are 1.2 I would keep the tweeters as 198 and convert the crossover to the 1.2tl- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The IC is blade/blade.--Gary--
Definitely first gen
I have heard the first gen decked out and they can easily hang with a set of decked out 1.2tl- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Can they be "Monolithed"?
Don't take experimental gene therapies from known eugenicists. -
For a small mortgage loan maybe
Some of those values on the first gen in a duelund cast or jdm would be more then some mortgage payments- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
