Polk RT300P amp
Sealevel
Hello, I have a Polk RT3000P plate amp in need of the transformer. Anyone know where I can find one?
Thanks for the help,
Greg in San Diego
Greg in San Diego
Best Answers
Does the transformer have any info printed on it?
Yeah unfortunately the transformer is not made anymore and I'm not sure if there's a suitable replacement.
I do have a spare brand new one of these plate amps in my basement, however I'm hesitant on selling it due to never knowing if I'll need a new one and because it's gone unused for 20 years, those two large filter caps (which are buldging a little bit) will definitely blow up so you'd need to get the amp tested and refurbished first.
Now... have you considered mating a plate amp from Parts Express to your RT3000p? It's arguably more economical to do, I only repaired my plate amps because they were easy fixes (broken solder joints due to being unleaded, and bad filter caps). If they ever totally died I'd either mate plate amps or just power through my complete rebuild project.
The Dayton Audio SPA300-D or Yung SD300 could work well!My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
Answers
Yes it has 95745S218ZV imprinted on it.
And a sticker that says T-2020-D assembled in Mexico
Ok, let's try this. Post a photo of the transformer and the label because I'm not finding anything with the info you posted.
Ok, here are some photos. I'm new to this forum just today, so hope they came through.
Much appreciated your input on this. My vintage 80's DJ system thanks you.
Ok, I was hoping there would be more info such as in this pic.
How do you know the transformer is bad?
I brought the amp to a local tech who said the transformer was bad, then to a second tech who confirmed this (I did not tell the second tech about the first diagnosis).
Very good. Since those numbers didn't turn up anything and without the specs makes it hard to source a replacement.
How about taking the good amp/transformer to your tech to see if they can determine the specs. -
I forgot to mention, the reason I asked is it is unusual for a transformer to go bad all on its own.
Yes, I agree. I have rarely seen a bad one myself. The fact that two techs found it to be bad tells me it needs to be replaced.
And yes, I have asked my tech to figure out the specs of the known good transformer.
Sometimes AC transformers are required to have an internal fusible link as a safety precaution.
You can try contacting this ebay seller near me in Wheaton, IL.
Electronetix LLC
1963 Brentwood Ln E
Wheaton, IL 60189
(630) 682-0159
https://www.ebay.com/itm/262285993254?mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338487047&toolid=10001&customid=130832X1592984X47e34bd22121de0c04f729176c1864d1Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
From the listing
If the power transformer is defective (this is a very, very rare occurrence) the unit cannot be repaired because the transformer is not available, and we will ship the unit back to you and refund your purchase less the cost of shipping and a $25 diagnosis fee. For your information, we have repaired hundreds of this amp model and have yet to find a bad transformer. So, while this is possible, is probably not worth worrying about.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank you for all your comments. My tech replaced the transformer with one from Nippon. I just picked it up and will test it tomorrow, I will let you know the outcome.
