Polk RT300P amp
Hello, I have a Polk RT3000P plate amp in need of the transformer. Anyone know where I can find one?
Thanks for the help,
Greg in San Diego
Best Answers
    F1nut Posts: 51,662
    Answer ✓
    Does the transformer have any info printed on it?
  • ChrisD06
    ChrisD06 Posts: 912
    Answer ✓
    Yeah unfortunately the transformer is not made anymore and I'm not sure if there's a suitable replacement.
    I do have a spare brand new one of these plate amps in my basement, however I'm hesitant on selling it due to never knowing if I'll need a new one and because it's gone unused for 20 years, those two large filter caps (which are buldging a little bit) will definitely blow up so you'd need to get the amp tested and refurbished first.
    Now... have you considered mating a plate amp from Parts Express to your RT3000p? It's arguably more economical to do, I only repaired my plate amps because they were easy fixes (broken solder joints due to being unleaded, and bad filter caps). If they ever totally died I'd either mate plate amps or just power through my complete rebuild project.
    The Dayton Audio SPA300-D or Yung SD300 could work well!
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
Answers
  • Sealevel
    Sealevel Posts: 7
    Yes it has 95745S218ZV imprinted on it.
    And a sticker that says T-2020-D assembled in Mexico
    F1nut Posts: 51,662
    Ok, let's try this. Post a photo of the transformer and the label because I'm not finding anything with the info you posted.
  • Sealevel
    Sealevel Posts: 7
    Ok, here are some photos. I'm new to this forum just today, so hope they came through.
    Much appreciated your input on this. My vintage 80's DJ system thanks you.
    F1nut Posts: 51,662
    Ok, I was hoping there would be more info such as in this pic.
    How do you know the transformer is bad?
  • Sealevel
    Sealevel Posts: 7
    I brought the amp to a local tech who said the transformer was bad, then to a second tech who confirmed this (I did not tell the second tech about the first diagnosis).
    F1nut Posts: 51,662
    edited June 2024
    Very good. Since those numbers didn't turn up anything and without the specs makes it hard to source a replacement.
    How about taking the good amp/transformer to your tech to see if they can determine the specs.
    F1nut Posts: 51,662
    I forgot to mention, the reason I asked is it is unusual for a transformer to go bad all on its own.
  • Sealevel
    Sealevel Posts: 7
    Yes, I agree. I have rarely seen a bad one myself. The fact that two techs found it to be bad tells me it needs to be replaced.
  • Sealevel
    Sealevel Posts: 7
    And yes, I have asked my tech to figure out the specs of the known good transformer.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,269
    Sometimes AC transformers are required to have an internal fusible link as a safety precaution.
    SCompRacer Posts: 9,077
    edited June 2024
    You can try contacting this ebay seller near me in Wheaton, IL.
    Electronetix LLC
    1963 Brentwood Ln E
    Wheaton, IL 60189
    (630) 682-0159
    https://www.ebay.com/itm/262285993254?mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338487047&toolid=10001&customid=130832X1592984X47e34bd22121de0c04f729176c1864d1
    VR3 Posts: 29,384
    From the listing
    If the power transformer is defective (this is a very, very rare occurrence) the unit cannot be repaired because the transformer is not available, and we will ship the unit back to you and refund your purchase less the cost of shipping and a $25 diagnosis fee. For your information, we have repaired hundreds of this amp model and have yet to find a bad transformer. So, while this is possible, is probably not worth worrying about.
  • Sealevel
    Sealevel Posts: 7
    Thank you for all your comments. My tech replaced the transformer with one from Nippon. I just picked it up and will test it tomorrow, I will let you know the outcome.
