Polk SDA 2 Project
Hi everyone,
Has been many years since I've owned a pair of vintage Polks. I have recently bought a pair of SDA2 which is in very good condition other than the tweeters not working.
Cabinet, grills, drivers, SDA cable all look in excellent condition. I plan to replace the tweeters with the newer ones, and maybe even do some of the upgrades.
I do have 2 questions ... well 1 question and a request.
1.
I am confident they are the original SDA2 based on the driver configuration. However according to the SDA handbook, the says this speaker should have an external fuse on the back, however my speaker doesn't have the external fuse. Am I correct in thinking that this is an SDA2 even without the external fuse?
2.
Do Polk still sell the replacement RDO tweeters? If so would anyone on here be able to buy them and ship them to me in Australia? I'll pay for it of course. Just you can't get them here.
TIA
    F1nut Posts: 52,244
    edited May 2024
    Post a photo of the front and one of the binding post area.
    Surely there is a Polk distributor in Australia.
    Here you go.
    https://au.polkaudio.com/contact-us
  • puunda
    puunda Posts: 127
    Sorry I thought I had attached phots. I tried to edit the original post to add photos, but can't.
    As far as Polk/Sound United here, there is an office. However many years ago I tried to order the replacement SL3000 / RDO drivers and they said they were not available in. Things many have changed. I will try them again.
    F1nut Posts: 52,244
    There will be a polyswitch on the crossover board, which takes the place of the fuse. The polyswitch is a resettable thermal device. It's common practice to remove the poly and replace with a .5 ohm resistor.
    It's also common to disconnect the SDA tweeter as it imparts a phasey effect.
  • puunda
    puunda Posts: 127
    So this is a confirmed SDA2? Did some SDA2 come with a fuse and some come with a polyswitch?
    I will check the drivers hopefully this weekend and see if it's the tweeters or XO which is the problem.
    F1nut Posts: 52,244
    The SDA II (not 2) only came with polyswitches.
  • Gardenstater
    Gardenstater Posts: 4,866
    edited May 2024
    puunda wrote: »
    Yes. Confirmed.
    The very early ones had a fuse and when they deleted it and went to the polyswitch they changed the resistor from 4.0 Ohm to 3.5 Ohm to compensate for the extra resistance of the polyswitch.
    Post edited by Gardenstater on
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • puunda
    puunda Posts: 127
    A few updates on this project.
    I contacted Sound United / Masimo here in Australia, twice and got no reply. I used the contact form, then I emailed their service department directly, and no reply to either. Based on my previous experience, the won't have the replacement tweeters, and even if they did, it would be prohibitively expensive.
    So I removed the drivers and measured them. 1 of the tweeters was open circuit. Got that repaired by a local repairer and hooked it all up today.
    It sounds ok, but it seems there is only sound from 1 tweeter on both the speakers. Only the tweeters on the inside work, the ones on the outside have no sound.
    I checked the SDA cable and it measures fine.
    Based on previously comments, I'm thinking the tweeters got disconnected. I will check the XO next
    F1nut Posts: 52,244
    You don't want the SDA tweeters working anyway as they impart a phasey effect.
  • puunda
    puunda Posts: 127
    So you're saying leave it as it is? Have only 1 tweeter on each speaker working?
    I've not checked the SDA woofer yet. Is there an easy way to do that?
    F1nut Posts: 52,244
    puunda wrote: »
    That's what I'm saying.
    To determine if the dimensional driver is working listen to the speakers with the SDA cable disconnected, then listen with it connected. The difference should be
    obvious.
    pitdogg2 Posts: 27,687
    puunda wrote: »
    obvious.
    Correct, on that model the dimensional driver will NOT work without the cable connected. You may hear some sound from the back wave of the active drivers playing coming through BUT once you connect the cable you should notice a huge difference just by touching the driver with the cable engaged and disengaged.
  • puunda
    puunda Posts: 127
    I suspect the SDA tweeter and woofer are not working. I've taken the SDA XO out and it appears to be ok - as in the cabling is all connected the components appear to be ok. The polyswitch measures ok too.
    So the drivers are ok and the XO is ok and the connection is ok. I'm guessing the SDA signal comes in from the other speaker? So that is where I'll check next
  • Gardenstater
    Crossover connections are OK you say. Did you check at the dimensional tweeter end to see if it is disconnected? Someone could have just removed the negative quick connect and it wouldn't play then.
    There should be resistance checks that can be done in the SDA Handbook, as well as the procedure to check out the SDA function.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • puunda
    puunda Posts: 127
    Everything measured ok and appeared to be working ok, so I could never figure out what's going on.
    Turned out to be a loose connection. The Pin-Pin cable doesn't fit snugly in the socket sometimes and you need to jiggle it. Once jiggled, it's working perfectly
    F1nut Posts: 52,244
    Blade/blade, not pin/pin.
  • Jimmymac1965
    puunda wrote: »
    Why
    [ibJimmymac1965[/i]
    puunda wrote: »
    Why
    Read the thread Jimmy, your answer is in it!
  • skipshot12
    skipshot12 Posts: 2,114
    edited July 2024
    Stupid question Jesse…
    Why does the sda tweeter, on the sda II’s, cause a phase effect and no phase effect on my sda SRS’s?
    Curious…..
    F1nut Posts: 52,244
    skipshot12 wrote: »
    Curious…..
    Because your model does not have a dimensional tweeter.
  • skipshot12
    Oh, I did not know that… thanks.
    SDA1c, SRS2, SRS2.3 & 2.3tl, SRS, SRS1.2 & 1.2tl all use a progressive point source tweeter arrangement.
  • emitter
    emitter Posts: 1
    posting from the future B) .
    @F1nut , sir if you’re still around: being that sda tweeter can be disabled to some great effect. in your experience will this approach the clarity of the 2B series?
    having unfortunately forgotten this audio gaff, i stumbled into ownership of 1As, coming from 2B i was disheartened to learn my new speakers my be awash in phase issues.
    F1nut Posts: 52,244
    I suggest you remove the SDA tweeter in each cabinet and disconnect at least one lead. Be sure to tape off any disconneced leads. Reinstall the tweeters and give your speakers a listen.
    The SDA 1a and SDA 2b are completely different critters. I've owned SDA 1a and SDA 2a, both crossovers completely rebuilt. The SDA 1a is a fine speaker. I listened to them for a long time with the dimensional active. I always found myself during a listening session looking around the room for, something. After disconnecting the dimensional tweeter, I didn't find myself looking for those, distractions.
    Between my SDA 1a and SDA 2a the seemed to have a wider soundstage, even with half the drivers. The only thing the SDA 1a had better was bass. The bass dug a bit deeper than the 2a.
