My idea for an outdoor system. ???
CH46E
I have a half acre back yard that we spend a lot of time in. Near I95. So the road noise has to be overcome when considering an audio set up.
I'm thinking this amp (great reviews on Amazon). Obviously it must be class D. Seems like plenty of power for these speakers. Skar Audio 8 inch 2 way Marine speakers to be mounted under my roofs overhang. And 1 of thier 10 inch Marine subwoofers. I'll plug the links in in the next post. The speakers will be easily hard wired to the amp that will sit just inside the house on a shelf in my laundry room.
Every portable "high output" Bluetooth speaker I've tried out there fails to delivery what I am looking for. On my third one now. About to return it.
Can you guys give some opinions please?
Also my biggest question/concern is a box that will hold up to the elements. I was thinking I could buy cheap prefabbed boxes for car audio. Strip the carpet off and spray them with a lacquer then dust them in white paint.
This would be in central FL outdoors. Yuk!
AMP
TDA7498E Bluetooth Amplifier Board 160W×2+220W Subwoofer 2.1 Channel Audio Receiver Power Amplifier Module with Treble and Bass Control for DIY Speakers https://a.co/d/8ipvGai
8 inch two way
https://www.skaraudio.com/products/sk8m-8-inch-marine-speakers-white
10 inch sub
https://www.skaraudio.com/products/SKM10-10-inch-marine-subwoofer?sku=SKM10WBD2 -
https://youtu.be/4xP8QsobctM?si=pH-flS4AhmmdK-Qf
Just an idea of the yard I'm trying to fill with sound. Took this today. She is in her happy place. -
Which BT speakers have you tried? For that size space it would need to be one of the expensive JBL models I'm assuming, or one designed for PA use.
Edit: This? https://www.crutchfield.com/p_109PBULTMT/JBL-PartyBox-Ultimate.html
It weighs 87lb ffs. -
Hahah lol, I just realized they make outdoor speakers. No need to retrofit some marine grade speakers. 😆 🙄
Revel M80XC speakers …
The best you can get ..
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
