Polk React Sound Bar - voice sync out
jjphilp
Hi. Just connected sound bar with HDMI. Arc3 enabled. Everything works well except sound bar voice is not synchronised with speach / lip movements in picture. What can I do to fix please? .
Hello,
Welcome to the Polk forum. I'll check with a product specialist at Polk for you. -
The suggestion is that there could be an audio delay adjustment as part of your TV's setup menu. If you can give us the make and model of your TV we can see if the owner's manual refers to this.
