Bad day on the water
F1nut
F1nut Posts: 51,997
    pitdogg2 Posts: 27,307
    Damn! One would think there would be a buoy attached to that pipe.
    That little signage is not much.
    F1nut Posts: 51,997
    I'm not familiar with the type of dredging equipment they seem to be using there. I can say I've run across many a dredging operation on the bay, but I've always stayed well clear of those.
    msg Posts: 10,472
    edited May 2024
    Oof.
  • gmcman
    gmcman Posts: 1,859
    Ouch. That sucks
    Upon departure.....
    "When did you say the next payment was due"
    msg Posts: 10,472
    Looks like a job for Flex Seal.
    F1nut Posts: 51,997
    Hilarious!!!
  • motorstereo
    motorstereo Posts: 2,367
    Wow; and I thought I had a bad on the water yesterday. I backed the boat in the water for the first time this year and had forgotten to put the drain plug in.
  • Willow
    Willow Posts: 11,255
    Always plug your bathtub before you play..... ;)
    xschop Posts: 5,407
    edited May 2024
    Will an insurance co. total-out that situation? Or do they have a dumb-**** clause?
  • stangman67
    stangman67 Posts: 2,328
    edited May 2024
    Our first day out was Sunday, after we returned I pulled my boat into the car wash and had forgotten to put down my nav light stanchion on the t-top. Needless to say I no longer have an all around white light. Whoops, theres a quick 150 dollars gone.
  • motorstereo
    Willow wrote: »
    That's actually the 2nd time I've done that. I'm hoping there won't be 3rd time but one never knows.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    xschop wrote: »
    Yes.
  • mrbigbluelight
    It might be helpful if you reminded your wife that although you love her,
    her continued negative oversights like that could very well have a negative impact on her yearly evaluation !
