LSi15 Bi-Amp
Zaigrith
Zaigrith Posts: 42
edited March 2011 in Speakers
I have an outlaw 990 and 7700 that I want to use to bi-amp the LSi15s. Has anyone here ever bi-amped while using balanced outputs?
When I used an Onkyo 606 to bi-amp I just changed the settings in the avr and it took care of everything.
Do pre-amps take care of crossover freq's when biamping or do you apply the same signal to both the high and low on the speaker?
One last question, is it a big deal if the wire lengths do not match or is the signal propagation in the wire negligible?
HT:
TV: Samsung UN55C8000 | Player: OPPO BDP-95 | Games: Xbox360 / PS3 | Party Music: Squeezebox Duet
Mains: LSi15 | Center: LSiC | Surrounds: LSiFX | Sub: SVS 20-39pci
Pre-Amp: Outlaw 990 | Power-Amp: Outlaw 7700
Cabinet: Salamander Synergy Twin 30 | Speaker Wire: Lowes 12AG w/ monoprice banana plugs
  • nguyendot
    nguyendot Posts: 3,596
    edited February 2011
    The crossover is in the speaker. You send identical signals to each set of binding posts.
    Main Surround -
  • Zaigrith
    Zaigrith Posts: 42
    Can you use a Y-cable to split a balanced signal? I am not sure what the input impedance is, but i imagine that this would be ok if it is very high. I am concerned that balanced signals might have some active components on either side that would not like to share the signal. Any thoughts are appreciated.
    HT:
  • nguyendot
    I would not split it, either get a pre-amp with dual outputs or use unbalanced.
    Main Surround -
    F1nut Posts: 52,406
    To properly bi-amp, you need to have the gain matched between the two amps. Since you are using two different models, they probably aren't matched. You also need to use external active crossovers. What you are trying to do right now is a complete waste.
    Have to agree with F1nut, but it is your coin,spend it as you will.
  • Zaigrith
    Zaigrith Posts: 42
    edited March 2011
    the outlaw 7700 is a 7ch amp and I only have 5 ch taken at the moment, so this seems like a good way to make use of those 2 ch especially since the lsi15s are so difficult to drive. Are you sure I need an external crossover? I am getting conflicting answers to this. I am thinking of using unbalanced output from the preamp splitting it and going to 2 ch for each main. Then I would run a speaker config to make sure that the levels are consistent throughout the setup.
    HT:
  • love2listen
    love2listen Posts: 172
    edited March 2011
    To bi-amp in the way you are describing, an external X-over is not needed. This form of bi-amping is not considered "true bi-amping," but is done by several here on this forum. I have used 4 of the 5 channels on my Sunfire Cinema Grand amp to bi-amp my Lsi15's and it did make a slight difference to my ears. In order to bi-amp in its true form, what F1 says is correct, an external X-over is required.
  • EvanRoberts
    EvanRoberts Posts: 1
    edited May 2024
    I have bi amped lsi15 with marantz sr5007. 4 marantz ma 500.
    Curious how it effects ohms and watts in them. I have heard they take a lot of power. Am I getting close to feeding them?
    pitdogg2 Posts: 27,921
    edited May 2024
    F1nut Posts: 52,406
    If they burp they are full.
