LSIM vs Reserve
    msg Posts: 10,459
    I do agree that the construction design and finish on the 703s is preferable to me over that of the plain box L200. Beautiful speaker. The L200s look pretty cheap imho compared to the 703s. Sound wise, though, the L200 is more pleasing to my ears.
    F1nut Posts: 51,962
    The L100 needs a sub, period.
    nooshinjohn Posts: 25,991
    Agreed. I do think that their intention with the L100 was for them to be surround or near-field speakers. With HT, a sub is already in the mix.
    treitz3 Posts: 20,088
    onwbwy wrote: »
    Hello all, I had both the PA LSiM 703 side by side with the PA Legend L100. I know that the L100 has a 5" woofer, is a 2 way system and the 703 has a 6.5" woofer and is a three way system. The sound reproduction from the 703 was unmistakably rich and natural compared to the L100. The L100 sounded totally drab. The difference was so drastic, I was shocked. So I checked all my equipment for a possible issue. I even switched over to a different amplification source and the stark difference was evident. After doing some work on the L100, I noticed that the crossover was somewhat cheesy. I'm familiar with the 703 crossovers and they are not exactly high end but looks like more engineering and effort was put into it. The total construction and finish that was put into the LSiM series is phenomenal compared to the L series. This is my opinion and I believe that most of you would concur if you experience both units.
    Hello. Please allow me to offer you a very warm welcome to Club Polk.
    F1nut Posts: 51,962
    onwbwy wrote: »
    Adding to my previous comment. Your comparison was apples and oranges. The L200 should have been compared to the 703 and I dare say the L200 would win as there is a disconnect between the mid and treble in the 703.
  • onwbwy
    onwbwy Posts: 8
    Thanks for your opinion. Everyone has one or two or three...
  • onwbwy
    onwbwy Posts: 8
    Thank you Tom for the warm welcome!
  • onwbwy
    onwbwy Posts: 8
    when I find an L200 at the right price I will compare it
    I don't believe that there will be a drastic difference but you never know.
    F1nut Posts: 51,962
    onwbwy wrote: »
    The difference is major.
  • onwbwy
    onwbwy Posts: 8
    You obviously experienced both the L100 and L200 side by side. What did you find different between the two? And, did you compare the L200 with the LSiM703 side by side also?
    msg Posts: 10,459
    There are some threads here with detailed comparisons from back when the Legend released, and there was a demo program.
    Another owner opted for L100s, and wrote about them here as well.
    Best way to search is to use Google from a computer (as opposed to a mobile device) and open a few tabs. Put this in your search bar:
    Term1 Term2 -TermToExclude site:forum.polkaudio.com
    Forum search tool might be better now, too, not sure.
    F1nut Posts: 51,962
    onwbwy wrote: »
    Like I said, the L200 is the better speaker, it's fuller and better balanced.
  • mikejedi0619
    mikejedi0619 Posts: 128
    The L200 is an amazing sounding speaker. Very well - balanced and nuanced , neutral but with nice sparkle. They can handle just about any genre of music , and do well with good power. The bass is unbeatable on these. And again the most neutral speaker I have ever owned in my life. These are my endgame music room only speaks. Along with my Yammie AS2200 running them :)
    Just my 2 cents ;)
  • onwbwy
    onwbwy Posts: 8
    OK, thank you. I respect your opinion. I will get back to the group when I'm able to compare the L200 with the LSiM703.
  • mpitogo
    mpitogo Posts: 520
    edited June 2024
    The worst performing for me are the LSi series. They sound dead and what are those stupid tiny port holes for? Both LSiM and Legend to me are on level. 707’s were my main 2ch until Nov 2019 and got moved to HT duties. I’ll probably keep them forever, not itching to replace one of the best sounding theaters.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
