Let's talk DAC's
  • erniejade
    erniejade Posts: 6,321
    Late to the party. I had Rich's Gustard X26 and for the $, I thought it was very good.
    For myself, I prefer the warmer sound so, I have stuck with the Boarder Patrol se-i I got from @Clipdat. It only can go to 96k but, I really like the way it sounds.
  • rainbow1919
    rainbow1919 Posts: 12
    IMO, Yamaha S801 should do really nice with the Polks and looks to have all the features you need.
  • PSOVLSK
    PSOVLSK Posts: 5,371
    VR3 Posts: 29,383
    Only 90 more posts to know what that was about!
    treitz3 Posts: 19,942
    My guess is he was referring to the USB DAC within the unit.
  • invalid
    invalid Posts: 1,439
    I have a DAC in my phone
    SCompRacer Posts: 9,077
    edited May 2024
    erniejade wrote: »
    Close, but X didn't mark the spot. :) It is an R26 fed via I2S from a Singxer SU-6 DDC.
    Clipdat Posts: 13,078
    edited May 2024
    I recently read a review of this R2R DAC in The Absolute Sound and it made me want to try it: https://www.aquahifi.com/formula.html
  • Dr_Wu
    Dr_Wu Posts: 356
    Used unit available at audiogon for about half off: only $9000+ :o
  • bcwsrt
    bcwsrt Posts: 2,361
    A phase switch … on a DAC?
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    billbillw Posts: 7,443
    Clipdat wrote: »
    That seems to be another rare R2R DAC that can also deal with DSD. Quite a bit pricier than anything from Denafrips though...
    VR3 Posts: 29,383
    edited May 2024
    If you research these R2r dacs that say they do dsd, it's always the same thing. There is a chip set of some kind involved.
    There is no such thing as a native R2r dac that can do dsd.
    edited May 2024
    Mine has a Direct DSD option which uses a 1-bit DAC for native DSD. I also have the option, like how most DAC's do it, which is convert DSD to PCM for the R2R. If you are feeding your DAC native DSD and it converts to PCM, I suggest trying it both ways. Feed it the equivalent PCM rate, no conversion, to see which sounds best.
    DSD64/128/256/512 PCM equivalents are 88.2/176.4/352.8/768kHz.
    edited May 2024
    bcwsrt wrote: »
    It's a great option that will allow you to compensate for a recording where absolute phase wasn't preserved or if something in your system is inverting phase. Steve Hoffman had some discussions about absolute phase in recordings at his forum. IIRC he mentioned some tracks in an album can be out of phase.
  • invalid
    SCompRacer wrote: »
    bcwsrt wrote: »
    A phase switch will allow you to compensate for a recording where absolute phase wasn't preserved or if something in your system is inverting phase. Steve Hoffman had some discussions about phase in recordings.
    Is the switch actually inverting phase or polarity?
    edited May 2024
    invalid wrote: »
    That's a good question. From the web...
    "The terms “phase” and “polarity” refer to two different things and cannot be used interchangeably. “Phase” implies a shift in time relative to some reference, while “polarity” is simply a reversal of the positive and negative terminals of an audio connection."
    I've always thought of phase as reversing the polarity of speaker terminals. The audio test CD I have has a test that refers to speakers being in or out of phase. The manual should explain what the phase switch does.
    EndersShadow Posts: 17,683
    Ok, I can’t hold my Salt-N-Pepa dad joke in anymore…. It’s been a week….
    “Let’s talk about DACs, baby…..
    Let’s talk about U… S…. B…..
    Let’s talk about all the good chips….
    And the bad chips that may be…..
    Let’s talk about DACs…..”
    Now I feel better.
    Clipdat wrote: »
    Re: Streamer/DAC, reading the review of this right now in Stereophile, they seem to like it: https://www.audioadvisor.com/camxn10?sku=NEW-CAMXN10
    I ordered one of these and I'm really impressed with it so far. I'm using the analog output and the built-in DAC is sounding good to my ears. Price to performance ratio is exceptional.
    mhardy6647 Posts: 34,905
    bcwsrt wrote: »
    That's for when the datastream consists of zeros and negative ones.
    B)
    edited May 2024
    Yup, the ol' phase/polarity imbroglio.
    Reversed polarity and 180 degree phase shift are, in the steady state, essentially the same thing -- in the sense that, on an oscilloscope, the nature of the difference in the two waveforms would be indistinguishable in either case. That would only be true in the steady state (i.e., two continuous since waves, either 180 degrees out of phase or with polarity of one inverted relative to the other).
    In a dynamic sense, though, the two cases are not the same.
    The source of these two images is currently down, but the URL from whence they hail is:
    http://www.davidbridgen.com/pol.htm
    Since music ain't (usually) pure (i.e., single frequency) sine waves -- the difference's not (quite) just a matter of pedantry.
  • displayname
    displayname Posts: 1,202
    So @displayname has “term limits” on his DACs lol…..
    Other way around. A stand alone DAC can hang around forever. But I fear the streamers might have a term limit if the apps stop getting software updates.
    To elaborate, I remember growing up a lot of people’s dads and grandpa’s could have vintage system that didn’t change for decades, driven by vinyl and CD players.
    But I’d imagine a steamer gets fully bricked in that situation. Maybe not, but I just don’t know that those pieces will have 20 year lifespans purely due to software no longer being supported. Just like cellphones.
    I need to walk back my statement. While in principle I support what I said, the simplicity of a streaming dac is nice, normally more cost effective, and higher quality options are coming out all the time.
    The more I think about it, the more I like the idea of eliminating a power plug and a USB/digital cable.
    A streaming dac might end up bricked, but in the mean time I can still cover a lot of ground excellently for a very manageable price point.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
