Tech Question
Dr_Wu
I would like to keep my streaming circuit direct from the DAC to the amp, using the streamer as a preamp. At the same time, if possible, I would like to use my turntable and CD running through my preamp. Have been advised to consider running the preamp to the amp via the XLR inputs, and the DAC as it is now via RCA inputs (the only output option for the DAC). The amp can be switched between balanced and unbalanced inputs. Unfortunately, my preamp does not have XLR out connectors. My thought is to use XLR/RCA adapters - I realize this will defeat the "balanced" feature, but over a .5 meter IC, should be fine. I understand that there may be a difference in gain between the inputs to the amp (XLR being higher than RCA), but I don't know if (a) that would be true using the adapters, or (b) if that is a problem.
Any thoughts or advice other than "just buy a new preamp"?
If this is the wrong section for the discussion, could a Mod move it? (2-channel, maybe?)
Thank you!
I mean, a line level connected switch would work fine for such an application (if I am understanding your "ask" correctly).
Sounds like you want to share two "sources" feeding the same power amp(?) -- one is the DAC's analog output (the volume of which presumably can be controlled upstream of it?) and the other is the analog output of a full function preamp.
If so -- then, yeah, an A-B switch. I'd recommend building one, allowing you to use whatever components (wire, jacks, and switch) you like. Otherwise I'd probably go "bespoke" and contract someone whose work you like to build you one. We're talking the simplest possible passive device for line-level signals.
Balanced vs. unbalanced isn't really an impediment -- just one more connection to switch for the balanced component.
If you need to convert balanced to unbalanced (or vice versa), a transformer is the best simple way to do it. Hifi baluns won't be inexpensive. I am sure there are active balanced/unbalanced converters for audio -- mostly for the pro (PA/sound reinforcement market).
PS and my apologies if I have misunderstood your question!
Can you look up the specs for the output V of the RCA and XLR of the DAC and also for the preamp?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
@mhardy6647 Yes, that's what I want to do. The DAC volume is controllable from the streamer (Lumin U2 Mini). Since the amp has a switch for balanced v unbalanced inputs, would that not do what your switch would?
@Gardenstater The Chord Qutest DAC has adjustable volume output: 1V, 2V, or 3V. It is currently set at 2V. The NAD C165BEE preamp has 2 preouts. I can't seem to find the Preout 1 value, but the Preout 2 volume is adjustable from the Preout 1 value to -12dB. Does this help address the gain questions?
Thanks to you both! -
I would think if the amp has a switch from single ended inputs to balanced inputs that is all you would need.
Thanks for that. Though I will say the switch suggestion would be much handier than getting to the switch on the back of the amp, a Parasound A21.
Regarding the possible gain discrepancy, is that a real concern given that the preamp does not have balanced outputs, and the IC cables from the preamp to the amp will not actually be XLRs; rather, RCAs plugged into an XLR adapter?
Why do you want to do this?
Pre out is specified at "> 10V into a 600 Ohm load", so the gain loss from just using the DAC would probably be pretty significant but if you have enough excess watts it might not matter and may or may not sound better w/o the extra component. Just my 2c.George / NJ
iFi nano iDSD DAC
iPurifier3
One amp; two source circuits that I'd like to keep separate. Reason being, the digital circuit sounds better to me when I use the streamer as a preamp for volume control and connect the DAC directly to the amp (not through a second preamp).
I've been streaming exclusively with this setup for awhile. But, once in awhile I'd like to use the turntable or CD. Both of these components (and the NAD preamp) have been sitting "out of the loop".
Probably only makes "sense" to me.
You should see the circuitous pathway(s) used by various sources to get to my power amplifier.
Just kind of evolved. All unbalanced, though (just like me).
