Belles 22A Inputs
xsmi
xsmi Posts: 1,801
On my Belles 22A pre, only 2 of the five inputs seem to work. I contacted Belles back in February and they never got back to me. So, I think I'm going to open it up. Can anyone tell me what I should be looking for, besides loose wires? Thanks
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    pitdogg2 Posts: 26,980
    Doesn't look like a wire could be the problem.
  • xsmi
    xsmi Posts: 1,801
    Hmm, solder joints maybe?
    VR3 Posts: 29,404
    Depends on how it changes inputs. There are sometimes relays and such at work that can go bad
    But holy circuit board batman!
  • xsmi
    xsmi Posts: 1,801
    Any way to test?
    audioluvr Posts: 5,892
    edited April 2024
    My 21A had the same problem. The relays fail. I had Hi-Tech Audio replace all of them with better quality ones.
    PM me and I'll shoot you a copy of the receipt.
    F1nut Posts: 51,713
    The white blocks are the relays. Spec info is printed on them. Sounds like you should upgrade all of them to whatever audioluvr's tech used.
  • xsmi
    xsmi Posts: 1,801
    Thanks.
  • xsmi
    xsmi Posts: 1,801
    I count 9, correct? And which numbers are important for the replacements?
    F1nut Posts: 51,713
  • xsmi
    xsmi Posts: 1,801
    Thank you sir!
    billbillw Posts: 7,494
    Hopefully that solves it. If not, check the power supply caps and such. Get out the magnifying glass and look around the bottom of the board too. Cold solder joints are common on the board mounted RCA jacks. I've had to fix quite a few over the years. Anything that doesn't look smooth and shiny could be suspect.
    F1nut Posts: 51,713
    xsmi wrote: »
    Thank you sir!
    While you are in there with the solder gun warmed up replacing all of those nasty Dayton/Bennic caps would be an excellent idea. Seriously.
  • xsmi
    xsmi Posts: 1,801
    xsmi wrote: »
    Thank you sir!
    Great minds, bro!
