Commander 1.2tl, reporting for duty
VR3
Latest build for Polk SDA SRS 1.2tl
Tweeter Network
Clarity Cap CMR
Path audio
Mundorf mreu30
Jantzen inductors
Midbass/sda network
Mundorf supreme evo
Jantzen inductors with c coil sda inductor
Supra rondo internal wiring
Supra quadrax sda cable
Wbt binding post
Point to point wired
Laser cut padauk and maple substrates, mdf backed
Tweeter Network
Clarity Cap CMR
Path audio
Mundorf mreu30
Jantzen inductors
Midbass/sda network
Mundorf supreme evo
Wbt binding post
Those deserve to be mounted externally.Don't take experimental gene therapies from known eugenicists.
Nice work!
The best crossovers money can buy!
Beautiful workmanship! Someone is in for a sonic treat
Looking good!
One of these days....just one of these days, Trey will get better at his craft.....
Amazing work!!!
I'm not holding my breath.... -
Thanks guys for all the kind words! 😅🚀- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That’s some serious money invested there..
Nice Work!!! -
Perfection!"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Just curious, have you ever considered making some simple "before and after" frequency/impedance measurements of the crossovers?
I can't speak for him but I do know this. The tolerances for some (not all) manufacturers isn't exactly what I would call, "close". In some cases, the tolerances were obviously not checked prior to assembly, so the numbers would naturally be off.
FWIW.
Thank you guys for the kind words 😁
Hey Ken!
I usually do not have the stock crossovers or speakers here. I do know the c coil drops the impedence a good bit but any capable modern amplifier will handle the difference.
Most of what I do is what's been established over the last decade amongst the collective. I attribute some of the sound quality improvements to how I wire the ptp network as I negate alot of wire and unneeded connections found on a circuit board build. This latest iteration was my replacement for the old monastery series build and incorporating some things I learned in the grande build.
I do wish we took measurements when Sean's was here but his pair had been modified previously so it wasn't purely stock either.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
FWIW.
Absolutely. I have pulled caps from the old stock crossovers that were 50% or higher out of tolerance- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Beautiful craftsmanship! Thanks for sharing the photos!
You make me almost miss my old SRS's...almost.
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Beautiful work !
I’m curious as to what the total cost is for all those components, ballpark?
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Cost?
Lots…. And that’s just the components used, good stuff right there. -
Thanks guys!
I don't generally discuss pricing on the forum but feel free to reach out via pm or check my site.
I consider the parts used here to be about the best available without doubling or tripling the cost again. Also builds like this take about 100 hours of labor from conception to shipping, sometimes more.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
....and I can assure you that he doesn't slack around when it comes to these builds. When he's on it, he's ON IT!!
I have a totally stock pair of 1.2TLs in PA that I would like to upgrade (someday soon). You can use my crossovers as a "guinea pig" for testing if you would like.
