Commander 1.2tl, reporting for duty
VR3
VR3 Posts: 29,429
Latest build for Polk SDA SRS 1.2tl
Tweeter Network
Clarity Cap CMR
Path audio
Mundorf mreu30
Jantzen inductors
Midbass/sda network
Mundorf supreme evo
Jantzen inductors with c coil sda inductor
Supra rondo internal wiring
Supra quadrax sda cable
Wbt binding post
Point to point wired
Laser cut padauk and maple substrates, mdf backed
    xschop Posts: 5,185
    Those deserve to be mounted externally.
  • gmcman
    gmcman Posts: 1,849
    Clipdat Posts: 13,095
    The best crossovers money can buy!
  • motorstereo
    motorstereo Posts: 2,342
    Beautiful workmanship! Someone is in for a sonic treat
  • monepolk
    monepolk Posts: 1,154
    treitz3 Posts: 19,992
    One of these days....just one of these days, Trey will get better at his craft..... :p
  • Conradicles
    Conradicles Posts: 6,343
    Amazing work!!!
    pitdogg2 Posts: 27,052
    treitz3 wrote: »
    I'm not holding my breath....
    VR3 Posts: 29,429
    Thanks guys for all the kind words! 😅🚀
    Toolfan66 Posts: 18,065
    That’s some serious money invested there..
    Nice Work!!!
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,771
    Perfection!
    Harry / Marietta GA
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,308
    Just curious, have you ever considered making some simple "before and after" frequency/impedance measurements of the crossovers?
    I can't speak for him but I do know this. The tolerances for some (not all) manufacturers isn't exactly what I would call, "close". In some cases, the tolerances were obviously not checked prior to assembly, so the numbers would naturally be off.
    FWIW.
    VR3 Posts: 29,429
    edited April 2024
    Thank you guys for the kind words 😁
    Hey Ken!
    I usually do not have the stock crossovers or speakers here. I do know the c coil drops the impedence a good bit but any capable modern amplifier will handle the difference.
    Most of what I do is what's been established over the last decade amongst the collective. I attribute some of the sound quality improvements to how I wire the ptp network as I negate alot of wire and unneeded connections found on a circuit board build. This latest iteration was my replacement for the old monastery series build and incorporating some things I learned in the grande build.
    I do wish we took measurements when Sean's was here but his pair had been modified previously so it wasn't purely stock either.
    VR3 Posts: 29,429
    treitz3 wrote: »
    FWIW.
    Absolutely. I have pulled caps from the old stock crossovers that were 50% or higher out of tolerance
  • SeleniumFalcon
    Beautiful craftsmanship! Thanks for sharing the photos!
  • xsmi
    xsmi Posts: 1,801
    You make me almost miss my old SRS's...almost. :D
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • gyosa
    gyosa Posts: 770
    edited April 2024
    Beautiful work !
    I’m curious as to what the total cost is for all those components, ballpark?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • gmcman
    gmcman Posts: 1,849
    gyosa wrote: »
  • skipshot12
    skipshot12 Posts: 1,972
    Cost?
    Lots…. And that’s just the components used, good stuff right there.
    Viking64 Posts: 7,556
    gyosa wrote: »
    VR3 Posts: 29,429
    edited April 2024
    Thanks guys!
    I don't generally discuss pricing on the forum but feel free to reach out via pm or check my site.
    I consider the parts used here to be about the best available without doubling or tripling the cost again. Also builds like this take about 100 hours of labor from conception to shipping, sometimes more.
    ....and I can assure you that he doesn't slack around when it comes to these builds. When he's on it, he's ON IT!!
    VR3 Posts: 29,429
  • Libertyc
    Libertyc Posts: 915
    I have a totally stock pair of 1.2TLs in PA that I would like to upgrade (someday soon). You can use my crossovers as a "guinea pig" for testing if you would like.
