Polk Monitor 10b tweeter upgrade
brotheryang
Hi all! Just got a pair of Monitor 10b’s, and the tweeters are exceptionally harsh to me. I have seen there are replacement tweeters that may help? I am (hopefully) including a picture of the tweeters I have currently. Thank you in advance for your input and expertise!
Those are the SL2000. You want to replace them with the RD0194-1.
Thank you! Are they easy to do? Do the leads solder on, or clip? Lastly, do you have a recommendation where to order them from? Sorry for all the questions, but I very much appreciate the help! -
The tweeters are very easy to change. The leads are attached with fastons (push on type terminals). You can order them from Polk, the Speaker Exchange or Midwest Speaker Repair.
