Burnt Voice Coil MW6500 and MW6511
    xschop Posts: 5,796
    I trried it in the 8TLs yesterday while I was working on some stuff at the shop. They sound correct in that x-over. Midrange was definitely veiled in the 5Bs.
    xschop Posts: 5,796
    I'm still interested in dissecting, measuring and repairing a 6511 if anyone has one lying around mag-shifted or burnt coil. Let me know. Thanks, Rob
    xschop Posts: 5,796
    Self-bump. Still looking for a burnt 6511 or two.
  • VSAT88
    VSAT88 Posts: 1,383
    BumP
  • Gardenstater
    Gardenstater Posts: 4,921
    After reading the Stereo Review analysis of the SDA 1C (Nov 89), I noticed that he said that the drivers employed edge wound voice coils. That would be the 6510 and 6511. Just an interesting lil factoid. I wonder how many other Polk drivers use that method of increasing Bl, and what model was the first.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,796
    The last two 6510's I had apart, I either didn't look close enough or the coils looked same as any other driver I've had apart.
    Now all other dimensions and materials between a 6503 and 6510 look exactly the same, even suspension hang, but now wonder what voice coil difference is.
    Of all the drivers, the spiders are all thin- weave except 6502's which have a stronger, thicker weave.
  • Gardenstater
    Just for the record, on my 1979 MW6500s I measure ID: slip fit to a 1.010 plug gage. OD: not round 1.057max, 1.054 min.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,796
    PM if you have any burnt-coil 6510's laying around.
  • chrispyfur
    chrispyfur Posts: 170
    If I can find a good replacement for my 6511 with a damaged/glued surround I could send that one your way if you're interested
    xschop Posts: 5,796
    edited August 2023
    Post a pic. I may be able to repair it for you.
    xschop Posts: 5,796
    Need 1 more burnt/mangled coil 6511 if you have one laying around.
