Can a 8 ohm LSiM706c and 4 ohm L600s be connected to same amp or receiver?
  • DapperD
    stangman67 wrote: »
    Great to hear those L600’s are being enjoyed!
    100%! That was such a win-win for the both of us!
  • DapperD
    stangman67 wrote: »
    I will tell you, Polk swears the LSIM and reserve/legend series are in fact timbre matched
    While I certainly am unqualified to make a statement regarding timbre matching here, I will say that in over 7 months of listening I never noticed anything 'off'. It just sounds great. The only reason I might possibly change the 706c is for esthetics.
  • stangman67
    stangman67 Posts: 2,334
    I am fully with you, that is one of the main reasons I didn’t stick with the L600s when that whole situation happened, I didn’t want to be on the hook to spend 2K on the L400 regardless of the timbre matching. Little did I know those decisions led to me spending way way way more than that 2K and ditching my HT setup completely.
    I am incredible glad they are working out for you, and glad to see you are sticking around the forum
    F1nut Posts: 52,406
    playzoffs wrote: »
    I know from prior experience that the HTS models will throttle the power on an amp that's that powerful.
    Huh???
  • Unknown
    edited September 2023
  • halo71
    halo71 Posts: 4,645
    I suspect the warning in the manual is because of the rare occasion when someone tried to have the amp switch on and off from the auxiliary power outlets that used to be included on some AV receivers. Those outlets couldn't provide much power at all.
    Why are you just repeating what Emyln already said on page 1??
    --Gary--
    Viking64 Posts: 7,814
    This is how bots work, folks.
    I bet jameswookyz has no clue that "his" nickname is "Jim" because it wasn't written into "his" algorithm. :p
  • Unknown
    edited February 2024
