Inductor DCR Question
I see several posts where folks go with "upgrade" inductors with lower DCR than the original. I am wondering why you wouldn't try to say with an inductor with similar DCR as the original? Otherwise, it seems to me that the characteristic of the XO could be quite different. What am I missing?
Apparently, resistances are fairly important in voicing. I was even told by one of the former Polk design engineers (ZSP) that I should stay with the same gauge internal wires as the XO was tuned with that gauge and length wire. Changing the resistance of the wire could slightly de-tune the XO. Notice that he provided a harness diagrams with length and gauge for the RTA-15TL.
Stan
Main 2ch:
HT:
Other stuff:
    VR3 Posts: 29,751
    Best bet is to keep the DCR the same as intended for solid results.
  • Unknown
    edited February 2024
  • skrol
    skrol Posts: 3,493
    Ok, that makes sense then.
    Stan
    Main 2ch:
    HT:
    Other stuff:
