Summing up SDA SRS mods so far.
I started poking around with my original sda srs’s that I bought new in 1987 from the audio/photo store on Yakota AFB. When I was….well, very young. The only thing I ever did with them over the past 36 years is enjoy them. I’ve had several different amps and sources put to them all top notch gear but just in the last year I got interested in finding out what could be done to make them better and more up to date. I started with tweeters which I had replaced about 25 years ago. I had 3 blown 2000’s so I called Polk. They sent me 8 SL2500’s. Don’t ask. I don’t know. I listened to them until recently when I started talking to Dave at DHS Speaker and he’s like “WHAT?” I could not order the 0194’s fast enough! I am now hooked into how awesome these things can be with some love , time and money. Thanks to the wealth of knowledge and expertise through this forum I started. I have had some misshaps along the way, starting posting…all over the place🥴 and now after learning a ton from all you folks am all sorted out and moving forward.
So far I have finished the following.
Rebuilt the stock binding cups with new posts and Speakon for sda interconnect.
Replaced tweeters with RD0194’s
Re sealed all drivers
Dynomat all drivers and PR
Replaced SDA inductors with low dcr Jantzen Coils.
Removed polyswitch’s
Results are very positive but the biggest impact is the Jantzen C coils.
I’m so stoked that I retired my Nak Pa7 for a pristine Threshold S500e.
I am going to start building new crossover’s very soon and can’t wait to hear the results!
Cheers and thanks to the many who have helped!
  • gregmoyers
    gregmoyers Posts: 142
    Correction
    S550e.
  • plastic_avatar
    Got pictures of your build?
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • gregmoyers
    Haven’t started the crossover’s yet. Here are cups and inductor mounting.ayk6d5ek6rmy.jpeg
  • gregmoyers
    Update: ordered all crossover parts
    Clarity, solen, Path, Mills. Will start figuring out a direct connect board for the low pass caps.
    While they’re apart I’ll put BH5 in. Stay tuned.
    Film at 11.
  • Schurkey
    Schurkey Posts: 2,130
  • gregmoyers
    VR3 Posts: 29,751
    I would highly recommend changing the tweeter internal wiring at. A minimum
  • skipshot12
    skipshot12 Posts: 2,156
    Damn nice job.
    Trey, why the recommend on the tweeter wiring?
    That’s something I did not do, curiosity.
    VR3 Posts: 29,751
    The tweeter wiring on the original sda srs is beyond life expectancy. The insulation is even turning to goo in the ones I have seen. Nasty wire
    F1nut Posts: 52,406
    skipshot12 wrote: »
    Damn nice job.
    All your chassis wire has turned green, replace all of it.
  • skipshot12
    Is there any reason to replace if there’s no oxidation… turning green?
  • Schurkey
    skipshot12 wrote: »
    If copper is green...it's oxidized.
    There was a time--thirty years ago or more--when Monster Cable had problems with this. They claimed it did not affect the sound...but they also replaced all the green stuff with fresh copper-colored wire as a "warranty" item.
    F1nut Posts: 52,406
    skipshot12 wrote: »
    All I see is oxidized.
  • skipshot12
    Mine look like new, not gonna mess with it.
    F1nut Posts: 52,406
    Yours
    What new looks like
    VR3 Posts: 29,751
    To be fair the one pictures belongs to @gregmoyers but I would say out of all the sda srs tweeter wiring I've seen.. Greg's the best looking and well.. There ya go
  • skipshot12
    Dang it F1, you went and done it….
    Need to take out some tweets and have a closer look.
    F1nut Posts: 52,406
    skipshot12 wrote: »
    Don't replace any clear jacketed cable with new clear jacketed cable as one never knows the quality of the jacket. Some have a chemical reaction between the plasticiser and the copper causing the copper to corrode/oxidize, while others do not. It's not worth chancing.
  • skrol
    skrol Posts: 3,493
    Example of the big green monster cable.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    VR3 Posts: 29,751
    thats a unique boutique feature called patina and is highly desirable.
    New York even has a statue featuring this on display for all of the world to see!
  • skipshot12
    skipshot12 wrote: »
    F1, what I’m understanding from the above is…..
    If I end up having to replace the wires I shouldn’t use clear jacketed wire, is that correct?
  • Unknown
    edited February 2024
    F1nut Posts: 52,406
    Correct
