Summing up SDA SRS mods so far.
gregmoyers
I started poking around with my original sda srs’s that I bought new in 1987 from the audio/photo store on Yakota AFB. When I was….well, very young. The only thing I ever did with them over the past 36 years is enjoy them. I’ve had several different amps and sources put to them all top notch gear but just in the last year I got interested in finding out what could be done to make them better and more up to date. I started with tweeters which I had replaced about 25 years ago. I had 3 blown 2000’s so I called Polk. They sent me 8 SL2500’s. Don’t ask. I don’t know. I listened to them until recently when I started talking to Dave at DHS Speaker and he’s like “WHAT?” I could not order the 0194’s fast enough! I am now hooked into how awesome these things can be with some love , time and money. Thanks to the wealth of knowledge and expertise through this forum I started. I have had some misshaps along the way, starting posting…all over the place🥴 and now after learning a ton from all you folks am all sorted out and moving forward.
So far I have finished the following.
Rebuilt the stock binding cups with new posts and Speakon for sda interconnect.
Replaced tweeters with RD0194’s
Re sealed all drivers
Dynomat all drivers and PR
Replaced SDA inductors with low dcr Jantzen Coils.
Removed polyswitch’s
Results are very positive but the biggest impact is the Jantzen C coils.
I’m so stoked that I retired my Nak Pa7 for a pristine Threshold S500e.
I am going to start building new crossover’s very soon and can’t wait to hear the results!
Cheers and thanks to the many who have helped!
Correction
S550e. -
Got pictures of your build?The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
Haven’t started the crossover’s yet. Here are cups and inductor mounting.
Update: ordered all crossover parts
Clarity, solen, Path, Mills. Will start figuring out a direct connect board for the low pass caps.
While they’re apart I’ll put BH5 in. Stay tuned.
Film at 11. -
I'm not wearing any pants.gregmoyers wrote: »Film at 11.
https://www.youtube.com/watch?v=-ht_yD2cfO0&ab_channel=TheBarryM8
I would highly recommend changing the tweeter internal wiring at. A minimum- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Damn nice job.
Trey, why the recommend on the tweeter wiring?
That’s something I did not do, curiosity. -
The tweeter wiring on the original sda srs is beyond life expectancy. The insulation is even turning to goo in the ones I have seen. Nasty wire- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
skipshot12 wrote: »Damn nice job.
All your chassis wire has turned green, replace all of it.Political Correctness'.........defined
President of Club Polk -
Is there any reason to replace if there’s no oxidation… turning green?
If copper is green...it's oxidized.skipshot12 wrote: »Is there any reason to replace if there’s no oxidation… turning green?
There was a time--thirty years ago or more--when Monster Cable had problems with this. They claimed it did not affect the sound...but they also replaced all the green stuff with fresh copper-colored wire as a "warranty" item.
All I see is oxidized.Political Correctness'.........defined
Mine look like new, not gonna mess with it.
Yours
What new looks like
To be fair the one pictures belongs to @gregmoyers but I would say out of all the sda srs tweeter wiring I've seen.. Greg's the best looking and well.. There ya go- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Dang it F1, you went and done it….
Need to take out some tweets and have a closer look. -
skipshot12 wrote: »Dang it F1, you went and done it….
Don't replace any clear jacketed cable with new clear jacketed cable as one never knows the quality of the jacket. Some have a chemical reaction between the plasticiser and the copper causing the copper to corrode/oxidize, while others do not. It's not worth chancing.
Example of the big green monster cable.
Stan
Main 2ch:
HT:
Other stuff:
YUM!!
thats a unique boutique feature called patina and is highly desirable.
New York even has a statue featuring this on display for all of the world to see!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The greening of the wire also gives it a more earthy and organic sound quality.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
F1, what I’m understanding from the above is…..
If I end up having to replace the wires I shouldn’t use clear jacketed wire, is that correct? -
Do not use clear jacketed wire, YES that is what @F1nut is saying.
The better alternative is Teflon or PVC jacket material.
Every clear jacketed wire I have used ALL did the same. Either the jacket material or chemicals used to make it are HOSTILE to copper. -
CorrectPolitical Correctness'.........defined
