Polk L600
I am on the verge of pulling the trigger on these. Only reservation I have is will my Parasound HCA1500 A do them justice? I know the specs say they have enough current and they do my 2Bs well, but are the L600 more demanding and will an old amp like this that has never been serviced get it done?
Yep, my name really is Bob.
    heiney9 Posts: 25,496
    edited February 2024
    Yes, they are absolutely phenomenal sounding speakers. But, you don't mention your listening space or your expected volume, for HT use, etc.
    I've used a 30wpc Pass Aleph 30 and now the Pass Labs XA25 (25wpc) and neither had issue driving the L600's to volume that runs me out of the room. I use mine in a simple 2ch set-up in a smallish room. Listening position is about 6.5-7.0 feet away. They need to be toed in for best performance.
    I continue to be blown away at how articulate, transparent and open they sound w/zero harshness. Bass is phenomenal. My 1C's, while different, don't really compete at all. I thought I'd miss them and I LOVE the SDA's, the L600's are so much better in every way. Never even thought about going back.
    Polk should be commended at how well these perform at their price point. They are a nice piece of furniture as well.
    If your amp is older and never service, perhaps it should be looked at, but I'd recommend that regardless of whether you were buying new speakers or not.
    nooshinjohn Posts: 25,994
    I just picked up a pair for a friend, but I need to swap parts over from the black cabinets to the brown ones. Polk was kind enough to help out getting the brown cabinets as warranty replacements as he really wanted the brown.
    Anyway, I will have an extra set of black cabinets I am thinking of building out. I will take pictures of everything and post them in a separate thread. Polk does not have any 7-inch drivers in stock, so I am looking at possible alternatives. but crossover's, tweeters, grills, turbine cones and everything else is available.
  • Emlyn
    Emlyn Posts: 4,814
    I ran a pair of LSiM707s to loud volumes with an HCA1500A. Never an issue with it or the speakers. The L600s should be fine with the amp. I would want something a bit stronger like a Parasound A21 with the L800s.
    I would not consider the L600s much more demanding to power than the SDA 2Bs but be aware that the L600s have an 86dB sensitivity rating which is relatively low compared to the SDAs. The 4 ohm nominal load will require more from the amp but current isn't a real problem for it. It may take a bit more volume to get them pumping.
    John did you happen to find out the costs of parts? If I'm going to ever mod the x-overs, I'd rather have the original set and a set I could mod.
    heiney9 wrote: »
    I will pm you the full list when I get it…
  • muncybob
    muncybob Posts: 3,264
    I've read so many positive comments about the L600 speakers that I'm willing to give up the 2Bs for them, something I never thought I would do. The family CFO has given me the green light so as soon as i can come to terms of parting with the 2Bs I'll make the move....I think :)
    The listening room is our "game room" which is 18' X 26' and, with the exception of a small bar at the opposite end of the speaker location and a 16' shuffleboard along one of the long walls, it is wide open. I would also rather the brown speakers but I could live with the black if it saves substantial funds.
    muncybob wrote: »
    The bad news is that if you order from Polk directly, neither pair is available at the moment. The brown ones have been out of stock since June. If you can swing it, the L800 may be a better fit, given the space you have in there.
  • muncybob
    The L800 would upset the CFO and I may go without dinner for a week or so. Can't afford to lose that much weight.
    The listening chair is about 10' away from the center of the speakers and the 2Bs actually did a decent job even if I was sitting at the bar at the far end of the room.
    Wonder why they can't keep up with demand for the brownies.
    There are no 7 inch drivers in stock.
  • Emlyn
    Emlyn Posts: 4,814
    Crutchfield has the brown walnut version of the L600 in stock. Says low stock. Full price. Going to be tough to find a deal on the Legend line unless a container ship shows up with them on it. I haven't noticed sale prices for quite a while on the Legend lineup.
  • rooftop59
    rooftop59 Posts: 8,120
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    Those are factory refurb's, so just beware they are not new and I would check to see if Polk will honor the warranty.
    Nothing necessarily wrong with refurb's......as long as you know you're getting refurb's.
    Also check Audio Advisor, sometimes they have open box for a great deal.
    P.s. I see they come with a lesser warranty.
    treitz3 Posts: 20,104
    Um....the warranty....how can they deal with that if everything is out of stock and has been for seemingly a while?
    Just sayin'...
    Already been since last May for some of these...
  • rooftop59
    I have bought polks from them refurb no problem. I have never had a problem with passive speakers. What the hell do you people do with your speakers?!?
    Game Room 5.1.4:
    Bedroom 2.1
    Good question. I have been in this hobby for 40 years. I blew (or more likely, overcooked) a tweeter at an audio event where the folks there wanted more and more volume.
    Way too much IMO but it was what it was.
    muncybob wrote: »
    Well, I pulled the trigger on the refubs in walnut. 2 yr Polk warranty included. Should be here before next weekend. Now I need somebody to buy my 2Bs.
    First indoor speakers we've bought in 20+ years.
    Congrats! You're in for a real treat! Be aware these take quite a bit of time to break in, at least in my experience. You may find if you can set them up optimally you may no longer need your sub.
    IMO, run them for awhile past break in without your sub to really get a feel for what they can do. The bass is really impressive.
    Be sure and post along the "break in" way........
    rooftop59 wrote: »
    I wasn't really commenting on the nature of refurbs (good or bad) but to be aware they were refurbs, that's all. I've bought refurbed and open box stuff all the time. It's a good way to stretch the $$$$.
  • muncybob
    It was a toss up between open box black and the refurbs. Black $200 cheaper, but no warranty from Polk. When I realized that it was a no brainer, besides the Mrs likes the walnut better. Now it's a waiting game, just hope we don;t have any major winter storms here or the driver won't even think about coming up our road.
  • Emlyn
    Emlyn Posts: 4,814
    Looking good! Polk refurbs have always arrived to me looking like brand new.
  • muncybob
    Well packaged and not a blemish on them, can't say that for the box though.
    Toolfan66 Posts: 18,169
    Emlyn wrote: »
    THIS^^^^ I would never have a problem ordering their refurbs..
    Viking64 Posts: 7,621
    Kex wrote: »
    damaged box, flattering package.
    My stage name was "Damaged Box" but I changed it to "Flattering Package".
    IMO, they need to be toed in more than you think. Experiment with placement, but ultimately toed in sounds best to me in my equilateral triangle listening position.
    They need a good amount of break in too
    Congrats, can't wait to hear your impressions from first listen and beyond. They are a lot different than SDA's
    muncybob wrote: »
    My L600's that came paletted from Polk had a big gash in the box. Looked like a fork from a lift truck. Clean through the box and all other packing material. Made a very light scratch on the lower backside of the speaker.
    The light has to be right to even see it. I never pursued a replacement because of the hassle. Those speakers are heavy.
    Brock’s point about break-in time is not an understatement. Figure about 100 hours before they open up and around 200 hours before they really start to shine. Bass will continue to improve beyond that. It took about 300 hours for my L800’s to finally settle in to where they are now.
    Clipdat Posts: 13,100
    Using this L600 thread as an excuse to post the glowing TAS review: https://www.theabsolutesound.com/articles/polk-l600-loudspeaker/
  • muncybob
    That's the review that sealed it for me. They normally make my mouth water when talking about equipment that I would need to win the lottery to afford.
    So, I only have about an hour in with these. It was suggested to turn off the sub first, which I thought I had but didn't. As soon the sound started I about jumped out of my chair....way too much bass. The sub was set to play nice with the SDAs but the L600s don't need that. I turned it off and the bass was "nice" with moderate volume but I would not describe it as giving a tactile feeling(which playing the Van Morrison album is not something to expect anyways). So I decided to add the sub with crossover and volume settings adjusted properly and wow, what a difference.
    Other than the bass, first impressions could be summed up by my wife's comment when she strolled into the room, they are so "clear". I've sometimes felt I needed the lyric sheet to know what Morrison is saying. I was surprised to not feel that way.
    Soundstage is so different from the SDAs and in a good way. Location of vocals and instruments were very easy to pick up on. At times I really felt like Van was right there in front of me. I think I need to experiment with toe in though since the sweet spot seems very narrow, just the slightest change in position was noticeable. But in the right spot I was immersed and pleasantly surprised in how good they sound. If break in is going to make a them even better, I'm stoked!
