Denon DL 110 versus DL: 110A
Been thinking about trying the 110 cart and see now they have the anniversary edition out. Anybody had ears on the newer cart?
Yep, my name really is Bob.
  • I had the 110 on my turntable for a couple years. It is a good entry level high output moving coil cartridge. I have not heard the new Anniversary edition. I preferred the dynamics of a Dynavector 10x to the Denon on my system, but at twice the price, that's to be expected.
  • muncybob
    muncybob Posts: 3,267
    Some reviews had me thinking of trying the 110 to see what, if any, improvements I can hear from my Shure cart. Would love to try the 10x too, but further down the road...too many other projects taking my $$ right now.
  • When we were buying the DL110 for $99 from Comet Supply back in the day it was a good value and great sounding, but at its current pricing, I'm not so sure that value proposition is there at it's current retail of $399 (unless you are importing from Japan in the low $200s). I tried it on a Rega P3-24 I had at the time and liked it but wasn't blown away by it. I think I had a Goldring 1042 on a Music Hall MMF5 I was comparing it to and IMHO the 1042 was better and almost equal in price back then. I did like it better than the Ortofon Blue.
  • After switching to a low output moving coil cartridge and hearing for the first time, everything I was missing with moving magnet and high output moving coil cartridges, I will never go back. There is no comparison. It is similar to listening to a song from an MP3 file vs. FLAC
  • muncybob
    I've never heard a low output cart(to the best of my knowledge), but can appreciate the mp3 comment. So, are there any low output carts in the $400 range worth trying? Also, would I have to stay with a Denon headshell?
  • dromunds
    dromunds Posts: 10,141
    Keep in mind you’ll likely need a step up transformer for a LOMC. Is that what you’re using, Newbie308? If so, that will add to cost.
  • My preamp accommodates both MC and MM, so the need for a step up transformer was not a factor for me. There is a multitude of LOMC phono cartridges in the $400 price range that are very good, and an entry level phono preamp that has MC inputs is not very expensive. There is a Denon step up transformer on FB Marketplace near me for $75.
    Ortofon Quintet red
    Grado Platinum 2
    Audio-Technica AT-OC9
    Denon DL-103 (if you have the correct tone arm)
    Hana EL
    And if you look around, there are a lot of lightly used or NOS cartridges on the various online resale shops. You could probably get a cartridge that cost $800 new for $400 used if you are patient. IMO it would be worth the investment.
