Denon DL 110 versus DL: 110A
muncybob
Been thinking about trying the 110 cart and see now they have the anniversary edition out. Anybody had ears on the newer cart?
Yep, my name really is Bob.
I had the 110 on my turntable for a couple years. It is a good entry level high output moving coil cartridge. I have not heard the new Anniversary edition. I preferred the dynamics of a Dynavector 10x to the Denon on my system, but at twice the price, that's to be expected.Enjoying the journey while never attaining the destination.
Some reviews had me thinking of trying the 110 to see what, if any, improvements I can hear from my Shure cart. Would love to try the 10x too, but further down the road...too many other projects taking my $$ right now.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
When we were buying the DL110 for $99 from Comet Supply back in the day it was a good value and great sounding, but at its current pricing, I'm not so sure that value proposition is there at it's current retail of $399 (unless you are importing from Japan in the low $200s). I tried it on a Rega P3-24 I had at the time and liked it but wasn't blown away by it. I think I had a Goldring 1042 on a Music Hall MMF5 I was comparing it to and IMHO the 1042 was better and almost equal in price back then. I did like it better than the Ortofon Blue.
After switching to a low output moving coil cartridge and hearing for the first time, everything I was missing with moving magnet and high output moving coil cartridges, I will never go back. There is no comparison. It is similar to listening to a song from an MP3 file vs. FLACEnjoying the journey while never attaining the destination.
I've never heard a low output cart(to the best of my knowledge), but can appreciate the mp3 comment. So, are there any low output carts in the $400 range worth trying? Also, would I have to stay with a Denon headshell?Yep, my name really is Bob.
Keep in mind you’ll likely need a step up transformer for a LOMC. Is that what you’re using, Newbie308? If so, that will add to cost.
My preamp accommodates both MC and MM, so the need for a step up transformer was not a factor for me. There is a multitude of LOMC phono cartridges in the $400 price range that are very good, and an entry level phono preamp that has MC inputs is not very expensive. There is a Denon step up transformer on FB Marketplace near me for $75.
Ortofon Quintet red
Grado Platinum 2
Audio-Technica AT-OC9
Denon DL-103 (if you have the correct tone arm)
Hana EL
And if you look around, there are a lot of lightly used or NOS cartridges on the various online resale shops. You could probably get a cartridge that cost $800 new for $400 used if you are patient. IMO it would be worth the investment.Enjoying the journey while never attaining the destination.
