Blackhole 5 BH5 Crap these days..
Toolfan66
Toolfan66 Posts: 18,160
edited February 2024 in DIY, Mods & Tweaks
For what this stuff cost now, you would think their quality would at least stay the same..
Sad days!!
Should call it Grayhole0
    VR3 Posts: 29,535
    That doesn't even look like blackhole 5. Like a complete redesign
    VR3 Posts: 29,535
    Would be curious to see how this compares
    F1nut Posts: 51,944
    Looks like they have eliminated the firm top skin and made the solid layer towards the bottom slightly thinner.
    Very disappointing!!!
    xschop Posts: 5,344
    It's their new line...BS-5
    I think for what Blackhole cost these days with the lack of quality it was, I would use that sonic barrier.
    F1nut Posts: 51,944
    So, six 12x12 inch pieces for $330.00.
    Yep
    pitdogg2 Posts: 27,233
    Toolfan66 wrote: »
    If you're thinking about this, forget that noise about the cutting steps and find a friend with a band saw. That is how I cut my blackhole 5.
    Makes life much simpler and it cuts like a dream.
    VR3 Posts: 29,535
    Table saw works great as well
    Toolfan66 wrote: »
    Yeah, I don’t know, if I knew about the BH5 before I ordered it I might have jumped on it, and gave it a shot, at least it looks like it’s on the same level as what BH5 was in quality.
    I will be thinking about it though.
  • motorstereo
    motorstereo Posts: 2,359
    Has anyone opened up their box after a few years with bh5 installed? Hopefully the adhesive holds the strips securely?
    It ain't going anywhere, when I down modded my 1.2tl's to sell them, I did look at that, I even tried putting my finger under it to see how it was holding up, that adhesive is some tough stuff..
  • I don't think it is comparable to BH5 because it doesn't have the panel resonance layer. It is like a BH4 (if you will). No-Rez is different from BH5 in that it doesn't have the floating vinyl layer with a small layer of closed cell foam underneath, but it does have the panel resonance control elastomeric layer. Closed cell foam is better for preventing sound transmission but open cell is better for sound absorption, which is pretty much what we are dealing with in loudspeakers. No-rez doesn't purport to be a product that is designed for car doors.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Nobody is talking about No-Rez..
  • Gardenstater
    Gardenstater Posts: 4,801
    Toolfan66 wrote: »
    Sorry if I wasn't clear. In the first two sentences I was referring to the ResoNix Guardian product. I brought up the No-Rez again because I think it should be considered as a better product for loudspeaker interiors.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • joebass3
    joebass3 Posts: 311
    VR3 wrote: »
    Table saw is great but stick with your initial cut. If you're a perfectionist and your first cut was slightly too big, NEVER try to shave a 1/16" off of this stuff using a table saw and rip fence. Ask me how I know. Hint, it didn't end well! Gruesome pics available upon request...
