Blackhole 5 BH5 Crap these days..
Toolfan66
For what this stuff cost now, you would think their quality would at least stay the same..
Sad days!!
Should call it Grayhole0
Sad days!!
That doesn't even look like blackhole 5. Like a complete redesign- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Would be curious to see how this compares
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Looks like they have eliminated the firm top skin and made the solid layer towards the bottom slightly thinner.
Very disappointing!!!Political Correctness'.........defined
President of Club Polk -
It's their new line...BS-5Don't take experimental gene therapies from known eugenicists.
I think for what Blackhole cost these days with the lack of quality it was, I would use that sonic barrier.
So, six 12x12 inch pieces for $330.00.Political Correctness'.........defined
If you're thinking about this, forget that noise about the cutting steps and find a friend with a band saw. That is how I cut my blackhole 5.
Makes life much simpler and it cuts like a dream. -
Table saw works great as well- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yeah, I don’t know, if I knew about the BH5 before I ordered it I might have jumped on it, and gave it a shot, at least it looks like it’s on the same level as what BH5 was in quality.
I will be thinking about it though. -
Has anyone opened up their box after a few years with bh5 installed? Hopefully the adhesive holds the strips securely?
motorstereo wrote: »Has anyone opened up their box after a few years with bh5 installed? Hopefully the adhesive holds the strips securely?
It ain't going anywhere, when I down modded my 1.2tl's to sell them, I did look at that, I even tried putting my finger under it to see how it was holding up, that adhesive is some tough stuff.. -
I don't think it is comparable to BH5 because it doesn't have the panel resonance layer. It is like a BH4 (if you will). No-Rez is different from BH5 in that it doesn't have the floating vinyl layer with a small layer of closed cell foam underneath, but it does have the panel resonance control elastomeric layer. Closed cell foam is better for preventing sound transmission but open cell is better for sound absorption, which is pretty much what we are dealing with in loudspeakers. No-rez doesn't purport to be a product that is designed for car doors.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »I don't think it is comparable to BH5 because it doesn't have the panel resonance layer. It is like a BH4 (if you will). No-Rez is different from BH5 in that it doesn't have the floating vinyl layer with a small layer of closed cell foam underneath, but it does have the panel resonance control elastomeric layer. Closed cell foam is better for preventing sound transmission but open cell is better for sound absorption, which is pretty much what we are dealing with in loudspeakers. No-rez doesn't purport to be a product that is designed for car doors.
Nobody is talking about No-Rez.. -
Sorry if I wasn't clear. In the first two sentences I was referring to the ResoNix Guardian product. I brought up the No-Rez again because I think it should be considered as a better product for loudspeaker interiors.George / NJ
iFi nano iDSD DAC
iPurifier3
Table saw is great but stick with your initial cut. If you're a perfectionist and your first cut was slightly too big, NEVER try to shave a 1/16" off of this stuff using a table saw and rip fence. Ask me how I know. Hint, it didn't end well! Gruesome pics available upon request...
https://youtu.be/hVpBT41c-gc
https://youtu.be/DqkP_28ncD4
