JBL Basspro Hub - 11"
muncybob
My daughter just bought a 2021 Maxda CX-9 and wants to replace the Bose sub. I have not heard it yet but she states it just doesn't deliver. She's looking at the JBL Basspro Hub - 11" sub that fits in the wheel well somehow. My subs in the past have always been enclosed in a box of some sort so I have no experience with these wheel well mounts. Are they worth it?
Yep, my name really is Bob.
nothing huh?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Read up on it…looks like it’s self contained, cool sub2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Looks like it would work pretty well.
I figured you would need to remove the spare, I was wrong.
https://www.crutchfield.com/S-D7oS7WcB9PO/p_109BASPROB/JBL-BassPro-Hub.html -
I just don;t understand how you'll get quality bass, esp if the unit is covered. I see how it will probably rattle the heck out of your car, but good sounding bass?Yep, my name really is Bob.
50hz is 22 ft long, should be good- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
