You’re doing it wrong…
12829313334118
    mhardy6647 Posts: 35,242
    I think it's The Big Omelet.
  • Jstas
    Jstas Posts: 14,996
    Well, you do have to crack just a few eggs to make an omelet but I guess if you're making "The Big One", you gotta crack ALL the eggs!
    Expert Moron Extraordinaire
    The Mother of All Omelets.
  • tonyp063
    tonyp063 Posts: 1,137
    The unreleased Zappa album
    Viking64 Posts: 7,629
    tonyp063 wrote: »
    "Dweezils Ripped My Flesh"
  • motorstereo
    motorstereo Posts: 2,371
    OleBoot wrote: »
    Pretty good quality u joint right there. The universals are what used to break when my foot slipped off the clutch as a young fellow. Then losing one or 2 needle bearings in the grass when putting in a new joint made for even more misery. Don't miss those days in the least.
    F1nut Posts: 52,009
    Judging by how new and shiny that driveshaft is that's not the first one they tore up.
  • daddyjt
    daddyjt Posts: 3,144
    ― Aleksandr Solzhenitsyn
    SCompRacer Posts: 9,123
    treitz3 Posts: 20,123
    F1nut Posts: 52,009
    That is SO wrong
    msg Posts: 10,473
    treitz3 wrote: »
  • bcwsrt
    bcwsrt Posts: 2,517
    If ya'll have ever fallen into and then tried to climb out of that era F-body, in a strange way, it makes some sense, especially as I/we grow older!
    Brian
    msg Posts: 10,473
    edited February 2024
    I remember driving a friend's Camaro once back when that body style first came out, and repeatedly banging my forehead on the idiotic windshield trying to see over the fenders while parking. It took three or four hits before the futility of conscientious parking sunk in. So, if you ever see one parked way out away from other cars in a lot, that's why.
  • bcwsrt
    bcwsrt Posts: 2,517
    Try cleaning the inside of one of those windshields. Stretch Armstrong even b!tched about it.
    Brian
    bcwsrt wrote: »
    Heck, I have trouble doing some of the lower reaches of Mrs. H's CR-V's windshield.
    I am certain that my age has nothing to do with this at all.
    I have used those before. They do actually work pretty good.
  • daddyjt
    charley96 wrote: »
    I’ve been using one of these exclusively for interior vehicle glas for a couple years. Make a job I use to hate somewhat tolerable.
    msg Posts: 10,473
    daddyjt wrote: »
    charley96 wrote: »
    Is it really streak free? Do you use a cleaner with them? I agree with everyone else, interior windshield cleaning has to be the most awkward job in vehicle cleaning.
    I've just wound up going with a sponge and light soapy water, then a couple of rinses, and finish with a 6" rubber squeegee.
    Last step is a fresh microfiber towel to catch any leftovers as well as the edges and areas I couldn't get to with the squeegee.
    While this makes it much easier and faster, it's not without its drawbacks. Need to be mindful of any paper backed windshield stickers, for example. Dab, not wipe.
    Cleanest and easiest I've come up with so far, but only for easing the wiping. Angles are still awkward.
    Post edited by msg on
    F1nut Posts: 52,009
    Sprayway glass cleaner. Use it with rags, not paper towels.
    As I age, I can't contort like I use to. With arm extended my wrist can't take too much pressure. I find it easier to use the tool. I use a foaming window cleaner and get good results. You have to wash the pads from time to time. I use a microfiber soap with hand wash and air dry. You can damage microfiber with too much heat.
    If the microfiber gets soaked remove it and use a small square microfiber towel over the pad.
  • Getting rid of the cloudiness on the inside of windshields is definitely one of the most annoying parts of cleaning an interior. I used to wipe multiple times with a microfiber cloth and Sprayaway and it would still be cloudy in some areas. I read somewhere to try a magic eraser. I tried it with the Sprayaway and it definitely did a better job than the microfiber cloth, though it makes an awful noise.
    CottageChz wrote: »
    Hmm, never tried that before.
    pitdogg2 Posts: 27,341
    My go to I've found that takes off the plasticizer film from inside the vehicle is a natural chamois cloth. I rarely use any cleaner on the inside glass anymore. I wrap the chamois around sponge for the majority of the open glass and my hand for the tight areas.
  • daddyjt
    msg wrote: »
    Is it really streak free? Do you use a cleaner with them? I agree with everyone else, interior windshield cleaning has to be the most awkward job in vehicle cleaning...
    Yes, it is streak free. I use the Costco/Sam’s club aerosol spray window cleaner. I will never go back…;-)
  • motorstereo
    You guys actually clean your windshields?? I don't believe I've ever done that on either of my current 4 wheel vehicles. Maybe that's why I can't see the road at night.
