You’re doing it wrong…
12728303233116
  • HzTweaker
    HzTweaker Posts: 1,034
    Correct me if I'm wrong but I believe the Porsche's GT1 racecar of that era suffered from a similar fate.(?)
  • Jstas
    Jstas Posts: 14,995
    HzTweaker wrote: »
    Yeah but they weren't flipping over, they would get tail-happy and make abrupt left or right turns due to a loss of traction up front and power induced oversteer
    Expert Moron Extraordinaire
    msg Posts: 10,459
    I wish that would happen to Honda Civics with giant wings and bumblebee exhaust.
    Viking64 Posts: 7,617
    msg wrote: »
    There's no greater technological marvel than rear downforce on a front-wheel-drive sedan. :p
    msg Posts: 10,459
    "Dude bro, my Civic with the wing puts out SO much torque bro? [pause for deep vape] that my wheels brake [sic] loose. It's even worser when it's windy. It's because the cold air makes the air charge more denser. I'm glad I gots audomaddic, 'cause it winds up so fast bro I coulnt shift fast enough in manuul."
    billbillw Posts: 7,748
    edited January 2024
    msg wrote: »
    Fast and Furious fans would take offense!
  • daddyjt
    daddyjt Posts: 3,131
    ― Aleksandr Solzhenitsyn
  • daddyjt
    treitz3 Posts: 20,088
  • daddyjt
    And they said the El Camino was discontinued….
    mhardy6647 Posts: 35,203
    daddyjt wrote: »
    sure, my toaster oven has (at least) two of them.
    daddyjt wrote: »
    I mean, that's a pretty crazy looking gasket.
    I'll bet aliexpress's got 'em for $49.95 -- although the packaging might say Rambolghini.
    I would just cut a gasket out of that banana peel and call it a day.
  • Upstatemax
    Upstatemax Posts: 2,783
    daddyjt wrote: »
    If you’re worried about the repair bill, you shouldn’t own a Lamborghini anyway.
    It’s part of how they keep the posers out of their cars.
  • Willow
    Willow Posts: 11,251
    daddyjt wrote: »
    You could 3d print one for about.39c.
    msg Posts: 10,459
    Willow wrote: »
    daddyjt wrote: »
    You can print gasket material with a 3D printer? I didn't know that.
    Permatex's The Right Stuff became my go-to for form in place gaskets. Fast tack, fast cure, and fluid resistant in minutes. Been a while since I had to wrench on stuff, but it worked great in all my Lamborghinis.
    SCompRacer Posts: 9,121
    edited January 2024
    msg wrote: »
    Willow wrote: »
    daddyjt wrote: »
    My father and I tried that stuff (or the early 1980s equivalent) on the oil pump of my (now) wife's '77 Fiesta (lovingly monikered The Fiasco) after an oil filter change mishap. The operation was not a success. :# Unfond memories of that little adventure.
    I'll regale all y'all with some of the fun tales of the colorful ways that car used to break down some other time...
    That little blighter was fun to drive, though.
    Meanwhile, I need to go out and pull the Lambo into the garage. The snow's starting to accumulate, and I can hear it rusting. B)
  • Willow
    msg wrote: »
    Willow wrote: »
    daddyjt wrote: »
    No clue, looks like some thin piece of plastic on my phone.
  • daddyjt
    edited January 2024
    The longer you look, the worse it gets…
  • boston1450
    boston1450 Posts: 7,758
    Wow
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Willow
    daddyjt wrote: »
    It's quite smart actually. You can piggy back on those interconnects, you can cook a perfectly shaped egg and your amp will warm up much faster.
  • daddyjt
    daddyjt wrote: »
    That is supposed to have a description that says "Customer complained of sewer smell in the laundry room"
    You and I must get the same suggestion feeds on FB...I saw it this morning on the crapper.
  • daddyjt
    Yea - someone doesn’t understand how to plumb a vent stack, lol
    msg Posts: 10,459
    SCompRacer wrote: »
    Spilled paint at the golf ball factory again?
