Give me yo' best shot! (System)
135
    xschop Posts: 5,322
    Trigger alert....
  • halo71
    halo71 Posts: 4,637
    If you still have your 7Bs I highly recommend you try them!
    I sold the 7B's a little while back. I never hooked them up. Just have SDA's and Monitor 10's now. But I would liked to have tried this mod but never thought about it really.
    --Gary--
  • Geoff4rfc
    Geoff4rfc Posts: 2,926
    edited January 2024
    @Geoff4rfc The finish is brown tejus
    @marvda1 I can dig it. I've seen alligator covered speakers but never lizard. Check these out...I also have black and burgundy but these are worn the most.
    Set up: 11.2 HT + 2ch
  • HzTweaker
    HzTweaker Posts: 1,030
    Before the SR is an AQ NGRX:
    Let the burn in commence:
    mhardy6647 Posts: 35,183
    edited January 2024
    ^^^ Dude. I want a door like that!
    That is beautiful.
    nooshinjohn Posts: 25,972
    What Simaudio piece is that?
    โ€œWhen once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.โ€โ€” Thomas Jefferson
  • bem
    bem Posts: 103
    Itโ€™s a Simaudio 390 Preamp/DAC.
    SDA SRS 2.3 (non TL) with VR3 mods/RD0194 tweeters/hurricane nuts/Dynamit etc, Simaudio 390 Preamp/DAC, Parasound JC5, SVS (2) SVS SB-3000 Subs, Rega Planar P3 with Exact 2 cartridge, Niagara 1200 Monsoon power cable, Marantz CD5005 player.
    xschop Posts: 5,322
    Where'd you run off to?
  • lightman1
    lightman1 Posts: 10,797
    Piece of garbage hack system
  • lightman1
    Fight me in my front yard
    VR3 Posts: 29,520
    What towers are those
  • lightman1
    Amphion Creon 2
    VR3 wrote: ยป
  • xschop wrote: ยป
    Unlike some other F1tools, keyboard warrior isnโ€™t my only gig in life.
    Aka, life ๐Ÿ™ˆ
    Polk 7Bโ€™s modded
    Velodyne CT 100
    Rega Elex R
    RME ADI2
    Eversolo DMP A6
    Pro Ject Audio Carbon Debut
    Schiit Mani 2
    MacBook Pro
    Apple Music
    Tidal
    xschop Posts: 5,322
    Here at the CCP, it's a right of passage, a badge of honor to have gone through the fire, tempered yet unscathed. Well done my friend. :D
    treitz3 Posts: 20,069
    Before this thread gets off track because of a comment about another member of this forum. I politely ask of you to go F up his thread and leave mine be. Any further comments can go here >>> https://forum.polkaudio.com/discussion/199805/subwoofer-downgrade-from-10-to-8
    Give me yo' best shot! (System) is the topic of this thread. I'd like to keep it that way. Thanks.
  • HzTweaker
    Russ I believe the side firing woofers are suppose to be on the inside firing towards each other with that particular model.(?)
    The one thing I have found with the side firing woofer speakers is that it is completely dependent upon the room itself as to what actually sounds better. FWIW. YMMV.
    @recoveryone - I have this sneaking suspicion that you like bass....๐Ÿ˜‰๐Ÿ˜€
  • HzTweaker
    That makes since. They sounded great firing at each other in my room. Just a suggestion.
  • marvda1
    marvda1 Posts: 4,957
    Puritan PSM156
    Clipdat Posts: 13,100
    No, he doesn't.
  • marvda1
    edited January 2024
    Yes, he does :) He can buy from a place like Crutchfield, and if he doesn't hear a difference, he can return them.
    Puritan PSM156
  • Joey_V
    Joey_V Posts: 8,603
    What speakers are those?
    Are those svs subs?
  • halo71
    halo71 Posts: 4,637
    edited February 2024
    Little overkill, but I like it. JUST running the JBL's only. That's a 65" TV btw.
    --Gary--
  • gyosa
    gyosa Posts: 770
    halo71 wrote: ยป
    You need a few more speakers !
    ๐Ÿ˜‚
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48โ€ - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7โ€™s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65โ€ OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65โ€ TV - PATIO
