Harmon Kardon ST-8
I have a pristine ST-8 just pulled from storage and it seems the dreaded Hall Effect is Sensor might have gone bad.
Can anyone provide expected Voltages at the motor.
Thank You Peter
    F1nut Posts: 52,294
    You might try asking that question at AudioKarma.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,358
    edited January 2024
    The service manual is available at the vinylengine site, here is a tabulation of the voltages present at transistors:
    mhardy6647 Posts: 35,513
    edited January 2024
    @SeleniumFalcon beat me to it.
    https://www.vinylengine.com/library/harman-kardon/st8.shtml
    EDIT: It's a really comprehensive and intelligible service manual, too! B)
    SCompRacer Posts: 9,271
    edited January 2024
    I repaired an ST-8 for a friend. The motor had a bad hall effect sensor. I used a motor out of a donor ST-7. In my copy and paste notes, a post from diyaudio said a Dual CS 701 or 721 might be able to donate a hall effect sensor. I have no idea if there are substitute sensors that could be used.
    It's common for the base of the cueing air pot to deteriorate and crumble. I came up with a fix in the link below. Airpot would still made them at the time though it was a pricey replacement ($97 US in 2022).
    https://forum.polkaudio.com/discussion/197116/harmon-kardon-st-8-turntable-on-the-bench
  • SeleniumFalcon
    The designer of the Hall effect motor:
    very effective.
