Blu-Ray gets a little luvin
Retiring the cinnamon 48 with a carbon 48....hope to see a difference
Set up: 11.2 HT + 2ch
    pitdogg2 Posts: 27,229
    edited January 2024
    I moved up from cinnamon to chocolate several years back, it was subtle but there was a difference. Depending on the player I'd like to think you should notice a difference
  • Geoff4rfc
    Geoff4rfc Posts: 2,932
    Thanks! I've got the Panny 9000. I've installed the cable, gonna check out a bluray.....
  • rooftop59
    rooftop59 Posts: 8,120
    Geoff4rfc wrote: »
    So…worth the upgrade?
    Game Room 5.1.4:
    Bedroom 2.1
  • Geoff4rfc
    rooftop59 wrote: »
    Geoff4rfc wrote: »
    To be honest......no jump out at you differences visually. Audibly, a noticeable difference.
    I was hoping for a PQ improvement, but I may have to go from the Pre to the display to achieve that.
    All in all, worth the upgrade.
    edited January 2024
    My Oppo 205 goes directly to the TV, the audio HDMI goes to the pioneer Elite SC27.
    Look into the Oppomod.com website, if I remember correctly they have some upgrades for the 9000 too
  • Geoff4rfc
    @rooftop59 @pitdogg2 I don't know if it's placebo or what however I've been running standard blurays today then ran 4K Prometheus and noticing improved PQ in the way of cleaner detail in closeups.
    I'm going to see what kind of deal I can get on a Vodka 48 and try @pitdogg2 's method and run the carbon from the #2 HDMI port for audio and run the vodka in the #1 port straight into the display.
    This is exactly why I don't go vinyl....... :D
