I can't recommend one of these enough
kevhed72
kevhed72 Posts: 5,162
edited December 2023 in The Clubhouse
The first time I sat down at it I discovered how off the height and sitting position of my old desk was. The ability to stand and work on stuff sealed the deal for me.
  • GlennDog
    GlennDog Posts: 3,158
    I prefer standing whenever possible… Matter of fact, I bought a nice La-Z-Boy a couple years ago and hardly ever use it
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • kevhed72
    So since I am ahead of the game on cleaning the Joule, what gets cleaned with deoxit fader and what gets "cleaned" w deoxit gold? d9hlzjkwqu4o.jpg
    As the kids say....TIA
  • kevhed72 wrote: »
    Following. I need a primer on this as well.
    F1nut Posts: 52,002
    The only part you have open access to is the input selector switch at the rear. A light application of gold there should be more than enough. You can also wipe a little gold on the RCA jacks.
  • kevhed72
    Thanks Jesse. The volume control is a bit staticy at times. If I remove the knob should a drop of deoxit fader cure this?
    F1nut Posts: 52,002
    Hard to say as I'm not familiar with that particular pot, mine was different. It appears to be completely sealed, but take a look for any holes you can get some fluid into. Otherwise, remove the nut/washer holding the pot in place then apply a few drops at the base of the shaft with the pot facing up. Turn the shaft back and forth to hopefully work the fluid into the pot.
    Edit: I forgot to mention previously when doing the RCA jacks apply a small amount of gold in the hole. A foam tipped applicator works well.
  • Jetmaker737
    Jetmaker737 Posts: 1,129
    Got my wife a Vari desk for her BD a few months ago. She loves it.
    mhardy6647 Posts: 35,235
    ^^^ +1 (FWIW)
    The mobility of cleaning solution products like DeOxit (D5) is so high, it can usually find a way in to most controls, IMO and IME, sealed or not. Just like dust. ;)
    Sometimes it just takes patience and time. I've plenty of the former, although the latter's still a development area for me. B) At any rate, if one uses the "hit and hope" (or is that spray and pray?) approach, clean up excesses.
    txcoastal1 Posts: 13,519
    ...."clean up excesses"
