Solder
musicmorsels
Answers
Depends. What are you soldering?Political Correctness'.........defined
President of Club Polk -
Upgrading caps resistors on rti8s. New to this stuff and no experience
with doing this sort of work. Just trying to get as much info to lessen the chances of a screw up. I have some of your work and Vr3. Good stuff. -
I mean -- I like 60/40 Kester 44.
My father used it six decades ago, and I use it still.
I've personally used several types over the years. If I had to pick just one it would be Cardas quad. Sometimes I wish the diameter was a bit bigger, only sometimes 😜
I second Cardas Quad recommendation.Gustard X26 Pro DAC
I third the Cardas Quad Eutectic.Political Correctness'.........defined
I use Chipquik 63/37 and it's never once let me down. Use leaded, it's simply better in every way.
Unless you eat it, then you'll get lead poisoning, but I don't think you'll be eating any. Right?My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
Please vent your space and use a carbon filter fan at a minimum while eating the lead solder- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Agree with the above, you can get high lead levels from the fumes very easily as well.
What about from the dull side of tin foil facing the food, @pitdogg2?I disabled signatures.
Actually, I make a lead solder paste and smoke it out of a pipe.
You do need to ventilate though, but the solder fumes from leaded solder don't actually contain lead from the pretty extensive research I've done. They do contain other chemicals from the rosin core which will irritate your lungs pretty badly.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
That's the inlet side of the foil so you will be fine...Gustard X26 Pro DAC
DUDE! You have much to learn. IF that was the case then HOW do folks who use an indoor shooting range accumulate high lead levels?About 95% of all reported elevated blood lead levels in adults in the United States are work-related. Occupations that have the greatest risk include battery manufacturing, lead smelters, sandblasters, soldering, automobile repair, and construction workers.
Whatever you're using to research this is BROKEN
Some idiot points a pistol in their direction and pulls the trigger.... IF that was the case then HOW do folks who use an indoor shooting range accumulate high lead levels?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
I genuinely have no clue how people who use an indoor shooting range acquire high lead levels but to my knowledge:
The boiling point of lead is 1749°C, 63/37 melts at 183°C
The solder doesn't emit lead dust when being melted
The smoke and fumes from soldering are produced by the flux and rosin core
I cannot find the source you used and the only other source I can find which says leaded solder will put lead in your body is from the UK and that's one site. Every other site is saying that the lead itself isn't inhalable.
Obviously one should still use a fume extractor as it's very important to protect your lungs from the rosin and flux anyways.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Lead is vaporized at the base of the bullet from the ignition of the gun powder. In that smoke from the flux and rosin you had better believe there is also vaporized heavy metals.
Well, Well yes but that is the "hardcore" way LMAO !! -
That's a fair point. I will note the lead is vaporized because the explosion that is projecting the bullet is reaching thousands of degrees Celsius. The soldering iron is only ~230°C for 63/37.
Mind you, treating the fumes as if they contain lead is a good idea, but don't panic and get a blood test done if you've inhaled them.
I've inhaled my fair share and I can confirm my brain is fine... ehh maybe not but the fumes didn't cause it.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
I work in construction and in general most men say they don't need a mask for anything or to vent anything... Manly pride? Testosterone? I dunno.
One of the guys I had worked with for several years died after a lung related issue... He was maybe 50
All I am saying is... Things we do today may not show up for 50 years... Best to just realize we are walking plants and take care of yourself ebst you can... Or not! 😜- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Some people just don't wear protection... apparently it's cool!
Like bronchiolitis obliterans must be sick bro! I wish I could inhale as much asbestos, fiberglass, and other industrial chemicals.
My friends (who are around my age mind you) think it's funny that I wear hearing protection when using lawn equipment.
Guess who has hearing loss at the age of 17? Protective gear is so cheap, why on earth would you choose to save $20 over your own safety and protection.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Not to mention listening to earbuds/headphones too loud, listening too loud in the car, standing too close to the stage at concerts, etc. I pretty much quit going to concerts, but if I do, I wear ear plugs. I know...I'm a wuss, but my hearing is more important than seeing so-and-so perform. I'd rather be comfortable at home, and listen to my systemMy friends (who are around my age mind you) think it's funny that I wear hearing protection when using lawn equipment.
Bingo. I went to one concert and got so close to the speakers. I remember hearing literal cracking in my ears because of the sheer volume of people screaming. FORTUNATELY my hearing somehow recovered after a day but I literally have earplugs for concerts now.
My friends are okay with me asking them to put the music down in the car though. I have really sensitive hearing so loud sounds can get uncomfortable.
Sometimes, just sometimes, I'll crank my RT3000p to max for a song or two. It's 90-95 dB so I can do that every day for a week if I wanted, but I generally don't.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Ir’ve Ben soldering for yets und too daye hav had know illlllllll slide efforts.
Bullets leaving a banger after a rather hot explosion- sure. More damage from breathing the fumes from the powder being burned during that process. That’s why good indoor ranges have mandated fume extraction systems.
You would be instructed to wash your hands thoroughly with soap and cold water (so pores stay closed) after handling those items.
Damage from solder fumes - yes. I’ve experienced that in the form of headaches but it’s from the rosin core.
As mentioned above you can’t possibly get your soldering iron hot enough to vaporize any combination of the metals in solder. Maybe from just handling it?Aaron
Enabler Extraordinaire -
It's something I've contemplated. There's evaporation and then there is boiling. Molecules of a liquid can evaporate and escape the body of the liquid well below the boiling point. We know that the higher the temperature, the higher the evaporation. Could become more of an issue the more potentially toxic the liquid molecule is. One mitigating factor might be the molecular weight of liquid metals vs something like water however, and the fact that they are most definitely heavier than air. I think to look into this you'd need to look at "vapor pressure" to get an idea of how low the volatility of molten lead and tin is, compared to something like alcohol or water.
Temp. in C for 1 Pa of vapor pressure:
Lead 705
Silver 1010
Tin 1234
Copper 1236
The amounts are miniscule compared to something like water where the vapor pressure at 30 C is something like 4.2kPaPost edited by Gardenstater onGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
More, hopefully eye opening
information about the vapor pressure of lead vs. temperature. Even if you were to set your soldering iron to a pretty high setting of, say, 800F = 427C = 700K the vapor pressure would only be around 5.38 x 10^-7 mm of Hg = 7.17 x 10^-5 Pa ! That's like 14,000 x less than the example above at higher temp.
But when PPM of lead over time in the air you breathe can do you harm, who knows what is "safe"?
Everyone have a non nerdy Thanksgiving lol.
George / NJ
iFi nano iDSD DAC
iPurifier3
The worst part of welding and soldering is the fumes, soldering can be worse at times getting small streams of smoke in the face once in awhile, and for some reason you think you placed your face in the right spot, and you get hit in the face anyways, like it is personally attacking you.. LOL..
The smoke is mostly from the rosin.
