Ultra-Short Throw Projectors
Anyone knowledgeable and using one of these?
Would like to hear pros/cons, ease of use, best quality for lowest cost type recommendations, etc.
Please share your experiences.
Thanks in advance.
    billbillw Posts: 7,632
    edited November 2023
    Pay attention to the throw distance. It is critical.
    Overall, the short throw laser projectors are pretty cool and put up a surprisingly good image. They are however, probably best used as a living room type of setup. For a dedicated dark room theater, a ceiling or shelf mounted long throw projector will give a better image (if comparing similar price points).
    In a darkened room, these short throw projectors create a sorta light halo coming out of the projector that I find distracting. That wouldn't be an issue in a room that isn't fully darkened though.
    Good review here:https://www.youtube.com/watch?v=plUAmhJ06Zw
  • jbreezy5
    jbreezy5 Posts: 1,141
    billbillw wrote: »
    Any advice regarding what to watch for concerning the throw distance?
    I’m guessing longer throw is more better?
    jbreezy5 wrote: »
    Not better or worse but when I said pay attention, I meant that the throw range is pretty narrow on these, so your setup has to match that. They HAVE to be pretty close to the screen.
  • jbreezy5
    billbillw wrote: »
    Thanks guys, these references gave me a good intro to the technology and proper screens.
    Aways wanted a projector; this is tempting.
  • Irrenhaus
    Irrenhaus Posts: 1,103
    Hi,
    I have been using an Optoma CinemaX P2 for more than a year. I love it. It is bright compare to others. I use it on my living room on a 120" screen.
    You will need a fixed frame screen a drop down screen will not work.
    I got this one:
    https://www.amazon.com/gp/product/B00CYLOTPK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    https://www.projectorcentral.com/Optoma-CinemaX_P2.htm
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
