What wall mount for CSiA6?
I just bought a SR8015 and a center to convert my room to HT.
What are you using to wall mount heavy center channel speakers above the tv?
Ryan Jozwiak
"Because music was meant to be felt and heard"
polkaudio RTiA9
polkaudio RT35i
polkaudio PSW 404
HK 3370
HK FL8380
HK DVD 22
Adcom GFA 5500
Samsung 40" LCD 120 Hz
polkaudio RTiA9
polkaudio RT35i
polkaudio PSW 404
HK 3370
HK FL8380
HK DVD 22
Adcom GFA 5500
Answers
How about a shelf and use the leg on back of the center to point down.
Or put it below the TV. -
I second this as I once mounted my CSiA6 above the display using a shelf with a slight downward angle. I had attached an aluminum strip with a 90 degree bend, creating a lip to keep the center from sliding forward.Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I suggest not doing any of that and getting a wall mountable center channel like this
https://www.polkaudio.com/en-us/product/home-speakers/center-channel/signature-elite-es35/300366.html?dwvar_300366_color=Black
Or
https://www.polkaudio.com/en-us/product/home-speakers/center-channel/reserve-r350/300031.html?dwvar_300031_color=Black
A shelf can work as said above , I'm just not a fan of a big thick deep center channel like the CSIA6 above a display. I think it would look terrible.
You could also try and find a LSIC which also was wall mountable and worked very well.
https://www.ebay.com/itm/285273385154?chn=ps&norover=1&mkevt=1&mkrid=711-213727-13078-0&mkcid=2&itemid=285273385154&targetid=4580496737259333&device=c&mktype=&googleloc=&poi=&campaignid=418233788&mkgroupid=1230353745471221&rlsatarget=pla-4580496737259333&abcId=9300542&merchantid=51291&msclkid=304d692ca7cf1dd88af20c7dc00d88b2Dan
How it looks depends. If the TV is mounted basically flush with the wall then I suppose the CSiA6 would stick out a good bit, but so would the L & R, so the center really wouldn't look out of place.
If the TV is on top of a piece of furniture just pull the TV out from the wall a bit making the center appear not to stick out as far.
As far as the performance goes the CSiA6 is the stellar one.Political Correctness'.........defined
President of Club Polk -
Here’s an option:
https://www.amazon.com/Pyle-Speakers-Adjustable-Extendable-PSTNDW17/dp/B01HZMCP4E/ref=sr_1_3?keywords=center+channel+speaker+mount&qid=1699900237&sr=8-3Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
