Polk Monitor 10
  • joebass3
    joebass3 Posts: 311
    xschop wrote: »
    I imagine the 11's are rare compared to 10's.
    I'll say it again, the only great sounding set of 10's I've heard were converted to SDA's. But that doesn't mean a @westmassguy modded set of factory 10's wouldn't sound very good with the lobing issue nixed.
    I'm certainly no expert but I can say that when I did the @westmassguy mod and added cabinet bracing, my 10's became totally different speakers. I have a set of modded 7b's also and my go to speaker is definitely the 10's. In my room and to my ears they are better.
    xschop Posts: 5,180
    MTM redesigned tower enclosure with the PR on the side. Someone with CNC access could make a flat pack and have a little mail order business perhaps.
    One could just mount the drivers on the side of the cabinets MTM and plug their original holes?
  • MTM redesigned tower enclosure with the PR on the side. Someone with CNC access could make a flat pack and have a little mail order business perhaps.
    Or for the possibility that a side mounted PR sounds weird, a trapezoidal shaped tower enclosure could be CNC'd with the back wider than the front baffle and the PR could be mounted in the rear.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • lawdogg
    lawdogg Posts: 468
    xschop wrote: »
    I would like to hear a set of 10's that had the lobing issue addressed without converting them to SDA's.
    Easy to do, and free - just turn them on their sides.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • odcics2
    odcics2 Posts: 373
    One driver per frequency range works best.
    xschop Posts: 5,180
    lawdogg wrote: »
    xschop wrote: »
    The WAF factor just went south and taller stands are in order. B)
  • When I had my 7Bs horizontally oriented and mirror imaged by hanging them from chains up near the ceiling I never got the imaging that I had and now have when I put them vertically oriented on floor stands. Wouldn't the 10s have vertical lobing, which admittedly would not damage the soundstage as much?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
