old interconnect cable
alessandr0
gday,
I got a pair of L SDA 1A and of course the interconnect cable gone missing....
anyone can point me in the right direction where to find one ?
thankyou in advance
thankyou in advance
Answers
Ebay
The L means left channel. The other speaker should be marked with an R. If not, you have two left channel speakers.Political Correctness'.........defined
President of Club Polk -
He's in Australia. L means right channel and R means left channel.Gustard X26 Pro DAC
According to the SDA handbook, SDA 1A's use the blade/blade interconnect cable. I own 1A's. Midwest Speaker Repair sells a blade/blade replacement. I bought one for a spare, works great.
Again per the handbook, SDA 1B's also use blade/blade. However, a friend has 1B's and they use a pin/blade. I have read stories of the last models of one generation getting some of the changes of the next generation. I have not found a source for a new pin/blade cable. eBay or another forum member.
Good luck!
Current system: SDA-SRS, Carver Crimson 275 amp, 10 Octave LP-1R preamp
Previous system: SDA-1, Carver M-1.5t amp, Adcom GFP-1A preamp
I listen better than I used to, but I don't hear as well. -
You'll need to make your own by grinding off the ground petals of RCA ends or go to speakon connectors.
https://www.ebay.com/itm/164278009286 -
I suspect your friend has the 1C as Polk never made the 1B with a pin/blade socket/cable. In fact, the early 1C had the blade/blade socket/cable because the pin/blade had yet to be made.
If his have the pedestal base they are the Studio version of the 1C.Political Correctness'.........defined
I stand corrected, F1. I checked with my friend and his 1Bs are indeed blade blade. Yet another reason not to trust my memory. And these reasons are starting to pile up... really puts the Old in Crow.Current system: SDA-SRS, Carver Crimson 275 amp, 10 Octave LP-1R preamp
Ok, that's settled.Political Correctness'.........defined
