Blade/blade SDA question
ratpin
I’m sound checking some SDA CRS speakers and don’t seem to be getting an SDA signal when I adjust balance. The cable that came with the speaker had been sliced at some point. I just want to confirm that the wide blades should share the same wire as well as the narrow blades sharing a wire. I noticed the sockets in the back of the speakers are opposing with wide blade up on one and narrow blade up on one. Is that how it should be or do I need to flip the interconnect wires? Thanks
Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
The switch is inside the cabinet. So the wire color on the wide blade on one speaker will be the wire color on the narrow blade on the other cabinet.
Understand?
The wires on the cable itself you should get continuity between both wide blades. You should get ZERO continuity if you try between wide blade and narrow blade.
Understand? -
Weird. I wonder what’s going on. I should be able to confirm interconnect signal with balance adjustments correct? I’m getting no crosstalk.
Help me understand…lolPolk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol. -
Check the cabinet and make sure wires are on the correct socket blade and have a good connection. The blade/Blade socket can be your weak link. They seem to be fragile and the connection point where the blades go into can become loose with age where they do not make a good tight fit.
Is the Onkyo common ground?Political Correctness'.........defined
President of Club Polk -
Good call on the Onkyo, IIRC I thought they were.
Double check the SDA cable. If ok, then time to open up the cabinets.Political Correctness'.........defined
Perfect time to dump those X-overs for some CRS+ X-overs.Don't take experimental gene therapies from known eugenicists.
@VSAT88 may have some spare.
What MW drivers do you have in those?
6503,6510 in the stereo slot, and 6511's in the SDA slots are good to go. I prefer the 6502's in the SDA slot for more clarity.Don't take experimental gene therapies from known eugenicists. -
Bad advice, the drivers are different.Political Correctness'.........defined
That's right, Mine run 4 MW6503'sPolk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
Yes, He'd have to swap in a couple 6511's on the SDA slots too.Don't take experimental gene therapies from known eugenicists. -
YES and ROB those are so plentiful everywhere...Right. (rolls eyes) He'd have better luck finding dentures for chickens!
That's why I suggested 6502's. A worn set of 6502's has better suspensions than 6511's new lolDon't take experimental gene therapies from known eugenicists.
MW 6502 1.97 5.16 N 1.47 E - 3N/M 3.52 Ohms 44 Hertz
MW 6511 1.405 4.34 N 3.496 E - 3N/M 3.13 Ohms 29 Hertz
scratches head.... -
Other than the small DCR difference, I bet a worn 6502 will spec closer to a NOS factory 6511, if it even exists.
Scratches balls....Don't take experimental gene therapies from known eugenicists. -
Actually I'm looking at the FS being much better in the 6511 vs the 6502. Unless I'm misinterpreting the FS the 6502 cannot go as low.
That's free-air resonance at NOS factory specs. A nice broke-in 6502 goes down to 30HZ all day in a set of CRS+. A good 6511 will have a little more SPL in the lowest frequencies, but the trade-off is the 6502 reproduces the midrange with more clarity.....from experience.Don't take experimental gene therapies from known eugenicists.
My early CRS's have dual 6503Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
The passive radiator takes over at well above either of those Fs figures and therefore the energy is used to move the passive where the MW barely moves at all. Fs will always be lower in the speaker with the more compliant suspension, and with the higher moving mass.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Correct but @xschop advocated you switch out the CRS XO for the CRS+ XO which would mean you would need 2 mw6511's to replace 2 mw6503. -
Like I said, bad advice.Political Correctness'.........defined
Was the passive radiator different, for the different versions that used different MWs with different Fs and compliance? I would think that would effect the moving mass required in the passive to tune the system properly.
When I said before that the MW barely moves, I meant in the vicinity of the resonant frequency of the passive. It operates in phase around there and when the MW is pushing out, so does the passive. That's why it is in resonance. It assumes almost all of the displacement while the MW cone barely moves. I have seen my MWs literally going nuts far below that frequency, like when playing something like Also Sprach Zarathustra.
p. 12 of the SDA Handbook, says yes but only for the twin blade and not the pin blade CRS+. A bit perplexing......
Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
