Speaker box build for RC60i
Looking to build a sealed box for this speaker. I cannot find info on how much air space it needs. Anyone have an idea?
If...
Ron loves a film = don't even rent.
    VR3 Posts: 29,404
    Are you using it in ceiling? Just need to separate the front and back wave, ie mount it in the ceiling.
    Enclosures for in ceiling are usually fire boxes versus performance enclosures
  • Ron-P
    Ron-P Posts: 8,520
    VR3 wrote: »
    No, not in the ceiling. Just want to use it for my Halloween sounds but want to get the best sound out of it with the proper size box.
    If...
    VR3 Posts: 29,404
    Would be best to use like a big piece of plywood so like if you mounted it and then hung like a scare crow on it, etc
