Lighter product to use in place of Dyna mat or 2nd skin
Suggestion for a friend…
Subject about says it. He needs it damp sheet metal & absorb sound.
Pity Armacell doesn’t come sheets.
1000 thanks in advance.
Tony
*all connected w/Premiere ICs
  • Gardenstater
    Gardenstater Posts: 4,794
    edited September 2023
    Tony are you looking for a foam product or a constained layer damping product?
    I do remember coming across a closed cell foam sheet product that was adhesive backed designed to be used over the Dynamat like constrained layer damping materials.
    Could take me a while to find it.
    This is it:
    Post edited by Gardenstater on
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    audioluvr Posts: 5,982
    Spray on bedliner
  • gp4jesus
    gp4jesus Posts: 2,019
    …a foam product or a constained layer damping product?
    yes. A substance that dampes vibration and absorbs sound
    This is it:
    I anticipate seeing my friend today. I’ll also suggest spray Bed liner & PD’s Amazon link. One or more together should take care of biz.
    1000 thanks Guys
