Tweeter rebuild
I have some RTI4 tweeters that need repair. Has anybody ever replaced the tweeter driver or rebuilt them? I've see listings for replacement dome diaphragms. What would be the process of removing the driver from it's faceplate and replacing the domes?
Polk RTIA3 Fronts
Polk CSIA4 Center
Polk PSW Sub
Pioneer VSX-521-K AVR
And a friendly Labrador Retriever
Answers
  • So for these tweeters you'll struggle a lot more than if it were the older style ferrite magnets.
    Polk switched to neodymium for the RTi lineup and this resulted in them using some sort of glue/epoxy to hold the magnets on. Taking off the magnet to remove the diaphragm will be nearly impossible and you'll probably end up destroying the tweeter.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • ChrisD06 wrote: »
    Ok so it isn't just me looking at them and wondering where to begin then? lol Seems with the odd shaped faceplate and semi-permanently installed driver, Polk doesn't want them repaired?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt wrote: »
    ChrisD06 wrote: »
    It's not that they made them unrepairable, it's moreso they didn't factor in Chinese diaphragm replicas being on Ebay.
    It's disappointing you can't replace the ferrofluid but they have a BOM to work with and a certain cost, and saving a buck in one spot is a buck spent elsewhere. Can't blame them for gluing it even though it's annoying
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • I keep wanting to repair my RTI4's just as a fun project (as I recently picked up far superior RTIa3's), but I seem thwarted at every turn. I don't need the 4's, and would likely just put them into storage to be used as rears at some point in the yet-needed HT I'm planning in the basement in 20 years. Oh well. :#
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • Just sell the parts.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
