B&K Model 607 Tube Tester
For sale is a B&K Model 607 Tube Tester it is in working order and will test the majority of tubes that we tube users will use such as 12 series 12AX7-12AU7-12AT7- 6DJ8 Types 6SN7-12SN7-EL34-EL84-6973-6L6GC-5AR4-5U4GB ETC and hundreds more.
This is a cheap way to test your tubes.
$75.00 + 15.00 Shipping
    pitdogg2 Posts: 27,259
    edited September 2023
    I'm interested talk to me @snow.
    Give me the 411, is this solid state?
    Does it need to be calibrated?
    Has it ever been restored?
  • snow
    snow Posts: 4,358
    Hi yes it is Solid State, I don't think it needs to be calibrated at the moment it seems to test tubes pretty accurately and picks up low testing tubes and tubes with shorts accurately, I keep tubes that test high low and have shorts so that I can test them on tube testers that come my way.
    Regards
    Cool looks like you got all the books needed for the tube info and use correct.
    How does this compare to the Hickok 600a?
    I have one that was restored, but you cannot have too many testers .... can you? Lol
  • snow
    snow Posts: 4,358
    They are two different animals both test tubes of course but the B&K 607 is an emissions only tester where as the Hickok 600A is a mutual conductance tester, the Hickok can accurately match tubes where as the B&K cannot but you can still come close with the meter but not as accurate as the mutual conductance tester. And yes I don't think you can have too many testers, everyone should have at least two one as a spare. I have owned up to 7 at once and all tested some tubes that the others would not.
    Regards Snow
    Okay I'm thinking real hard on this. It's late and I cannot do anything atm, but tomorrow we can work out the details and figure it out.
    Keep me first in line please.
    Thank you
  • snow
    snow Posts: 4,358
    No hurry and yes you are first in line
    Send me a pm with the specifics and I will get you taken care of. PP okay?
    Thank you
  • snow
    snow Posts: 4,358
    Thank you
    Sure message sent.
    msg Posts: 10,460
    I was curious, is this B&K like *the* B&K?
    I'm not into tubes and don't wanna be. seems like a gateway to poverty and madness.
  • snow
    snow Posts: 4,358
    msg wrote: »
    Yes they are the same company Brüel & Kjær. The interesting thing about B&K tube testers is as a rule they tend to test lower or reject tubes that most other brands will pass or test higher so you can be pretty sure if a tube test good on one of the B&K testers it is indeed good. The one I currently use to test tubes with is a model 600 very few NOS tubes test above 80% on it where as a Western Electric KS-15750-L1 tester and a Hickok 539B tester and TV-7DU tester I owned at the same time would all test the same tubes at 100% or higher
    Regards Snow
    Post edited by snow on
    msg Posts: 10,460
    Hey thanks snow.
    I had to look this up after you posted the name. I was actually meaning B&K Components, as in, the audio company, not the tube testing company, and was wondering at first whether it was the same company, since I've never heard of another B&K in audio conversations.
    Looks like they're two different from what I turned up. Not to jam up your thread, but just a trivial knowledge share piece. But you tube guyses most likely already knew this :sB)
    Brüel & Kjær (Sound and Vibration Measurement A/S) - Danish multinational engineering and electronics company headquartered in Nærum, near Copenhagen
    https://en.wikipedia.org/wiki/Brüel_&_Kjær
    B&K Components - American audio and A/V company; John Beyer and Steve Kaizer
    https://en.everybodywiki.com/B&K_Components
  • snow
    snow Posts: 4,358
    msg wrote: »
    Hey thanks snow.
    Well this is not the first time I am wrong, thanks for the info.
    Regards Snow
    msg Posts: 10,460
    Ohhh, haha, once I saw what Brüel & Kjær did, I thought you were just meaning B&K instruments the whole time, and didn't realize I was talking about the audio gear company.
  • TroyD
    TroyD Posts: 13,124
    Disregard...see that it's sold....drat!
