Are SIGs fixed yet.
BlueFox
They used to be okay, then Vanilla s c r e w e d them up by making the sig font larger than post font.
It appears now the font is the same size as the post font size. It should be a little smaller than the size of the main text. However, this is better than before when it was huge.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Don't try to update your signature now. It seems to be even worse. I just tried to add a couple of things and it seems to have jumbled everything together. I tried to edit that back to the way I originally had it and its still messed up. SMH.
It's been a while since we've heard from you Bud. I hope you're doing much better.2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: Magnepan LRS w/Magna Riser stands -
I just joined and am having a similar problem separating my two systemsMan Cave: Denon AVR-X2600H, S35, S15 x4, LV12R Shop: Sansui 4000, SDA SRS 2
