Are SIGs fixed yet.
They used to be okay, then Vanilla s c r e w e d them up by making the sig font larger than post font.
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2021
    It appears now the font is the same size as the post font size. It should be a little smaller than the size of the main text. However, this is better than before when it was huge.
  • HzTweaker
    HzTweaker Posts: 1,090
    Don't try to update your signature now. It seems to be even worse. I just tried to add a couple of things and it seems to have jumbled everything together. I tried to edit that back to the way I originally had it and its still messed up. SMH.
    It's been a while since we've heard from you Bud. I hope you're doing much better.
    2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
  • ExJAck19
    ExJAck19 Posts: 12
    HzTweaker wrote: »
    I just joined and am having a similar problem separating my two systems
    Man Cave: Denon AVR-X2600H, S35, S15 x4, LV12R Shop: Sansui 4000, SDA SRS 2
