Question for SDA experts
billbillw
billbillw Posts: 7,797
edited March 2005 in Vintage Speakers
Kinda new to the vintage Polks. I've heard that the SDA speakers are very picky on amplification requirements. Something to due with special grounding requirements? Is there any truth to this?
I've been looking at a good deal on some SDA-2a locally and wondering if they will work with a Denon 90 WPC (x6) receiver or a Sony 100 WPC (x2) receiver.
Any help would be great.
Post edited by billbillw on
  • hoosier21
    hoosier21 Posts: 4,420
    edited March 2005
    they will play and work, but you will want to get a good power amp down the road, good luck.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • hoosier21
    edited March 2005
    are you dealing with a guy named Jack R?
    edited March 2005
    Hey Hoosier,
    What's up neighbor? Your just a couple counties away. No, not dealing with him, why?
  • hoosier21
    edited March 2005
    just wondering, a guy named Jack had a pair of SDA 2 in black studio for sale I was looking at a while back, thought they might be the same ones.
    edited March 2005
    I think I figured out what my brother was talking about, but I don't know if it has anything to do with amplification. I was just reading about a non-common ground SDA cable. What is the deal with these?
  • hoosier21
    edited March 2005
    don't worry right now about all that, if you are using a receiver, you will have no issues with the non common ground amp. Later if and when you buy a pair, and want to get a separate amp, then you can worry about it.
    Go and get them
    edited March 2005
    Thanks Hoosier,
    I do tend to get ahead of myself sometimes. I'll let you know if I get um.
