LINE-X or Rhino Linings Spray-on Truck Bed Liners
13»
    msg Posts: 10,450
    Toolfan66 wrote: »
    pitdogg2 Posts: 26,924
    Who's got a match?
    msg Posts: 10,450
    See @bcwsrt? If you'd just pick a bedliner color and get it done, stuff like this wouldn't happen.
    msg Posts: 10,450
    Why you goat sucking egg stealin Mortonite.......
    I mean this in the best possible way.....
    Shut up Scott!
    Say, Ivan - what is a Mortonite, anyway?
    All I could find was this:
  • bcwsrt
    bcwsrt Posts: 2,362
    I'd probably have had it done by now, but I've been fighting with the (expletive) cowl piece that I had to remove to get to the wiper linkage. Took it off and put it back together 3 times now and it's still creaking and squeaking like hell! Guess that's what happens when you take stuff "off" after 30 years that's only meant to go "on."
    Next week, hopefully! Black, though!
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    msg Posts: 10,450
    edited August 2023
    Scrape some chunks of Dynamat together, wad them up, and jam some in there to immobilize it. Maybe some little balls underneath, and a little in between the joints at the fender and firewall?
    I've been meaning to do this in some dash vents - little bits of Dynamat, without the backing. Had a break in years ago at work, and it was never the same after the repair work. Always creaking, especially in cooler weather.
    Also, it helps if you don't end up with extra fasteners, you Mortonite.
  • bcwsrt
    bcwsrt Posts: 2,362
    edited August 2023
    Yep! That is pretty much exactly what I'm gonna try next. I think I can get in there thru the vents without taking it off again and just wedge some "stuff" like that in there with my gun cleaning paraphernalia, or similar. I know the general vicinity where it's coming from, so that helps. Just don't want to go too nuts with it in case the Chinese bushings I used on the wiper linkage meet their ultimate demise again before I do and I end up having to take it apart again.
    Brian
    audioluvr Posts: 5,867
    msg wrote: »
    Yes it would.
    msg Posts: 10,450
    audioluvr wrote: »
    msg wrote: »
    Yes it would.
    Because it's not a Jeep.
    ~ Rob, circa 2023
  • bcwsrt
    bcwsrt Posts: 2,362
    edited August 2023
    msg wrote: »
    Shut up Scott!
    Haha!! I just saw this! Must've been too busy replying to your post above this one and missed it! I wanted to acknowledge it in case you thought that by not, I was one of the 50% stuck ups! 😂
    msg wrote: »
    Wednesday!
    Brian
    msg Posts: 10,450
    doi, I know, 'cause I told you try it.
    Now
    bcwsrt wrote: »
    Is it done yet?
    msg Posts: 10,450
    Too late.
    bcwsrt wrote: »
    msg wrote: »
    :D>:)B)
  • bcwsrt
    bcwsrt Posts: 2,362
    msg wrote: »
    Now
    bcwsrt wrote: »
    Is it done yet?
    Don’t tell me what to do!
    Brian
    msg Posts: 10,450
    edited August 2023
    bcwsrt wrote: »
    tony-soprano-junior-soprano.gifim-your-boss-jack-donaghy.gifim-the-boss-like-a-boss.gif
    but
  • bcwsrt
    bcwsrt Posts: 2,362
    Turned out awesome!
    Brian
    Toolfan66 Posts: 17,980
    Great choice, looks much better..
    msg Posts: 10,450
    Nice - that turned out great. It's kinda neat you didn't go over the bed rails. I like it either way, but for this truck, it's a sweet detail ending the coating just below.
  • charley96
    charley96 Posts: 341
    That turned out really nice!
