I found this and it's about the best, simplest explanation I've seen...lol
heiney9
V=IR, unless you own a Crown amp here at the CCP.Don't take experimental gene therapies from known eugenicists.
No wonder it's hard to take your opinions on sound seriously.Political Correctness'.........defined
President of Club Polk -
That was in light of your directed admonition IIRC. LolDon't take experimental gene therapies from known eugenicists. -
― Aleksandr Solzhenitsyn -
I like the circle best of all -- pretty much all you need to know to solve 87%* of all quantitative hifi "problems".
... and that expands to 92%* of all hifi problems when one also knows that impedance follows Ohm's law, too.
As to the illustration in OP -- the S&M theme of that particular analogy has always kinda rubbed me the wrong way.
______________
* Remember that 83% of all statistics are made up on the spot!
http://www.bomus.org/index.php
Well V = IR but doesn't necessarily sound rhe same as
E = IR. 🤔
Break up into groups and discuss.
This will be on the final !
👨🏫Sal Palooza -
Electricity is fun.
Fun fact: Voltage flows negative to positive with the electrons, but current flows positive to negative.
Here's essentially what the OP posted but with a hose instead.
Ohms law is awesome because you can know 2 factors of something and get the other 2. For instance: Resistance and wattage will tell you the current and voltage, or vice versa!
Another fun fact is that speakers only work because of AC (Alternating Current), if AC wasn't a thing, the loudspeaker wouldn't exist.
3 most important things for understanding how a loud speaker functions in terms of the electrical aspect is voltage, current, and frequency. Really fun stuff and I highly recommend learning about it because it answers a LOT of questions you never knew you had.
My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
