I found this and it's about the best, simplest explanation I've seen...lol
heiney9
heiney9 Posts: 25,620
    xschop Posts: 5,702
    V=IR, unless you own a Crown amp here at the CCP.
    F1nut Posts: 52,253
    xschop wrote: »
    No wonder it's hard to take your opinions on sound seriously.
    xschop Posts: 5,702
    xschop wrote: »
    That was in light of your directed admonition IIRC. Lol
  • daddyjt
    daddyjt Posts: 3,209
    ― Aleksandr Solzhenitsyn
    mhardy6647 Posts: 35,482
    edited August 2023
    I like the circle best of all -- pretty much all you need to know to solve 87%* of all quantitative hifi "problems". :)
    ... and that expands to 92%* of all hifi problems when one also knows that impedance follows Ohm's law, too. ;)
    As to the illustration in OP -- the S&M theme of that particular analogy has always kinda rubbed me the wrong way. :#
    ______________
    * Remember that 83% of all statistics are made up on the spot! B)
    http://www.bomus.org/index.php
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited August 2023
    Well V = IR but doesn't necessarily sound rhe same as
    E = IR. 🤔
    Break up into groups and discuss.
    This will be on the final !
  • ChrisD06
    ChrisD06 Posts: 929
    Electricity is fun.
    Fun fact: Voltage flows negative to positive with the electrons, but current flows positive to negative.
    Here's essentially what the OP posted but with a hose instead.
    Ohms law is awesome because you can know 2 factors of something and get the other 2. For instance: Resistance and wattage will tell you the current and voltage, or vice versa!
    Another fun fact is that speakers only work because of AC (Alternating Current), if AC wasn't a thing, the loudspeaker wouldn't exist.
    3 most important things for understanding how a loud speaker functions in terms of the electrical aspect is voltage, current, and frequency. Really fun stuff and I highly recommend learning about it because it answers a LOT of questions you never knew you had.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • mrbigbluelight
    Electron flow vs hole flow.
