Hook up
Poodoo
We'll need a little more to go on if you're looking for some advice, @Poodoo
Have you tried hitting the side of it yet?Gustard X26 Pro DAC
Hey! That's my trick.
They walk among us.Political Correctness'.........defined
President of Club Polk -
..It happens...
might not be getting notifications. must have forgotten to update their email address after moving. I've done this myself a couple of times.I disabled signatures.
That is sooo odd. I once had a buddy and he fell wrong. After that, he couldn't get his system to work either.Set up: 11.2 HT + 2ch
Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
You’d probably have your answer by now if you’d posted this in the actual “Hookup” board:
https://forum.polkaudio.com/categories/basic-hookup-wiring-questions
Brian -
For a hook up, try Tinder…The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
